Engine problems
Old 03-23-2009, 07:13 PM
MASTA SHAKE's Avatar
Engine problems
i have an 88 Toyota pickup with an older engine (80-85 somewhere around there) and i just got it started last weekend. when i started it it sounded fine but there was an incredible loud knock and then i reved by it self extremely loud then died. my questions are
I have an oil pressure gauge where do i hook it up? it has oil flow in to the gauge so where is the male side that i screw it onto and it is also very small a couple mm wide.
second why is it revving so high and then dieing?
third what are possible causes of the loud knock?
All the help is appreciated!!
Old 03-23-2009, 07:58 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Carb'd or EFI? Sounds like you have a big vacuum leak somewhere. All the hoses hooked up and in their correct locations?
Old 03-24-2009, 02:23 PM
carb but the truck used to be an efi but the guy we got it from took the efi and gave us the 22r.
im pretty sure all the vacuum lines are in correct but i will go through all of them again
steve miller
10-10-2015 01:40 AM
Yota.Jay
07-23-2015 08:08 PM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Engine problems
