electrical problems
Old Jan 13, 2007 | 08:18 PM
hmmwv15's Avatar
electrical problems
Ok, so I have no idea what could be wrong with my truck. When it warms up, the light for the e-brake and charge battery light comes on (brand new battery) and e-brake isn't on also. But it doesn't always do it. sometimes my radio, fog lights; anything electrical other than normal lights cut off completely. But the main thing is that it is all the sudden running bat sh** rpms. So what did I do? I adjusted the idle speed screw on the carb. So just tonight, my dad was driving it home and he revved it up high (when you rev it high, most all of the problems go away instantly) and then it almost died
-because I adjusted the idle screw way down- So if anyone has any idea what's wrong I would LOVE to hear some.
Old Jan 13, 2007 | 08:23 PM
Elvota's Avatar
Alternator is bad or going bad... would be my guess. Local auto parts shop should test it for free.
Old Jan 13, 2007 | 08:25 PM
CJM's Avatar
CJM
Sounds like the alternator as well, get a multimeter and get a reading off of it.
Old Jan 13, 2007 | 08:29 PM
hmmwv15's Avatar
ok, cool I'll probably try to test it tomorrow. I just hope it's not starting to die on me.
Old Jan 14, 2007 | 12:18 PM
hmmwv15's Avatar
Ok, so now that I have the new alternator in, It is running at super low rpms/idles really low. The engine will barely make any sound and vibrates the truck a bit. I have tried adjusting idle speed again but make little to no difference. What do I do?
Old Jan 14, 2007 | 07:38 PM
86SR522REEFI's Avatar
For the e brake lite check the brake fluid level.
Old Jan 14, 2007 | 07:43 PM
hmmwv15's Avatar
problems have been solved-I had to replace the alternator. Thanks for the input though, If you have an idea whats wrong with my idle speed, I'm all ears!
Old Jan 16, 2007 | 04:28 PM
Yotapup's Avatar
Make sure you ware getting ample fuel to carb, maybe filter? Then check float.
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
