| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
EFI conversion help
#2 (permalink) | |
Quote:
For all i know atleast a shop helped him with it though.
__________________
1990 4runner 3.0 v6 4inch superlift 529's front n rear 1200 pound marlin crawler clutch 35 1250 15 Bfg Km2's One DAy. Sas Duel cases. 3.4 and 37's |
#3 (permalink) |
OK HERE WE GO! Keep all of the old harness in place so you can splice into it when needed. It won't hurt a thing for the old harness to be left where its at. Now,as for the new donor truck all you will need is everything on the engine harness thru the firewall to the computer. When your at the computer(ECM), keep everthing going into the ECM and what is comeing out of the ECM about 5" inches past the computer, cut it there. as this is where you will splice in the keyed power and the constant power source. OK now back outside under the hood, make the truck you are putting the EFI into,look exactly like the donor truck it came out of. Trust me it will fit and if you are neat about it when your done it will look like it came that way. Drill a 2"inch hole into the firewall on the same side as the donor truck right along side the original truck harniss and run it thur there. You will need the wireing diragram from both trucks to find keyed power and constant power source. It only takes about three wires powered to run the hole thing.find them on the diragram and power only those wires, don't worrie about the rest of them it won't make a differance if there wired to anything. Under the hood just splice the temp and the oil pressure into the harniss form the donor truck. Use everthinng else like it is.You will also need a relay from the donor truck to run the fuel pump. The realy next to the heater will work. cut it out of the donor truck and splice in into a keyed power source. I hope this will help some. Got more Q's let me know and ill will do my best to help.
__________________
1980 Fuel INJECTED 22RE, 5"lift on 37'x12.50. Bobbed bed. Costs A FORTUNE, BUT LOVIN EVERY MINUTE OF IT! With TOYOTA, everything else is...Well everything.... else...! and I GOT Your JEEP THING ~ And it BURNS WHEN I PEE!! Last edited by Broomie's; 06-24-2008 at 03:18 PM. |
#4 (permalink) |
Bump Does anyone have a write-up on exactly which wires need to be spliced?? Do I need the EFI exhaust system to? What needs constant power and what needs switched power? I really want to have some know how when I jump into this project! I would take the entire wiring harness and change it but I think that the 1990 harness is a little different from the 1987 harness. I have done alot of searching on this and still have many questions! Any help is a great help!!
#5 (permalink) |
Note the 1990 and the 1987 have radically different harnesses.. This one is going to be fun.
__________________
http://www.22REturbo.net |
#6 (permalink) |
You can call you local Toyota dealer and ask to see if they have a wire diagram of both trucks you are working on. If you don't know how to read one it can be trickey. See if you can get help from a auto tec on what is keyed and what is constant powered. I've done this swap 5 time's now and each one is a little different. Take your time and it will work out,pluse its well worth it in the long run.And yes you will need to use the O2 sensor from the EFI exhaust system. Ether weild it in or use the exhaust from the other truck,it will bolt up.
__________________
1980 Fuel INJECTED 22RE, 5"lift on 37'x12.50. Bobbed bed. Costs A FORTUNE, BUT LOVIN EVERY MINUTE OF IT! With TOYOTA, everything else is...Well everything.... else...! and I GOT Your JEEP THING ~ And it BURNS WHEN I PEE!! Last edited by Broomie's; 06-24-2008 at 03:23 PM. |
#7 (permalink) |
Hey guys I am new here and doing the same thing other then I have a 93 22re and swaping into a 83 If anyone has info on the I would really like to hear from you. I Have already pulled the wiring harnesses and to the point of break with the dash and heater controls. as they are different obvioulsy. If anyone has some info PLEASE Help. call me if you want 253 307-6081 Name is John Thanks
#8 (permalink) |
well im glad im not the only one attempting this efi conversion i have an 81 toyota pickup and am swapping to a 91 head and intake and after ive purchased the head intake computer i just sat down and realized hey u know what i dont have a crank sensor crap all im trying to run here is fuel assuming i can run my 22r distrubutor on the 22re head ne thoughts on this doesnt the ecm need signal from the ckp to pulse the injectors or is it ran off the maf?? ne help would b greatly appriciated
#9 (permalink) |
I put a EFI setup out of an 90 pickup into my 87. I swapped the dash to use the new harness rather than splicing the wiring harness. Only draw back is now I have to open the door to roll down the window.
#10 (permalink) |
I'm thinking about doing it but I can't decide if it's worth the work rather than building up my 22r with a weber, header/exhaust and a few other things.
__________________
'83 pickup - SR5 5spd 22R, currently restoring/modding, future trail rig '99 4runner ltd - auto, e-locker, dd more to come '93 4runner - RIP :( |
| Tags |
| 22r, 307eficonversion, 90, conversion, efi, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22r EFI conversion | toy power | 86-95 Trucks & 4Runners | 4 | 06-12-2008 08:59 PM |
| efi conversion help | mr2george | 86-95 Trucks & 4Runners | 17 | 02-22-2008 08:05 AM |
| Superjoe's EFI conversion thread | superjoe83 | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 07-08-2005 12:19 AM |
| EFI conversion on Landcruiser | Yoda | Off Topic Talk | 2 | 07-23-2002 08:53 PM |
| EFI conversion in progress | Yoda | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 06-23-2002 10:39 AM |
