ECU Self-Diagnosis (Paper Clip)
Old 12-28-2011, 03:57 PM
A2theK's Avatar
Trying to check for codes using the paper clip method and I was just wondering if anyone else has had this problem.. Doing this on my other vehicle theres a very noticeable pause in between different codes yet when I'm trying on my 22re it just seems to flash over and over with no definite pause in between codes. I can see it flashes in between each flash somewhat slower than other times but.. seems wrong...
http://s59.photobucket.com/albums/g2...IMG_1250-1.mp4
Old 12-28-2011, 04:42 PM
MudHippy's Avatar
Yeah...that's what it does when you don't have any codes...nothing's wrong...perfectly normal.
Old 12-28-2011, 04:51 PM
A2theK's Avatar
Yeah thats what I was thinking.. Just didn't want to believe it since my truck has been running like absolute crap lately. Really sluggish acceleration in first through third gear. Had a big mpg drop, stumbling at low rpms and now its starting to idle bad..
Thanks for the info
Old 12-28-2011, 05:56 PM
TNRabbit's Avatar
Replace O2 sensor.
Check for vacuum leaks.
Old 12-28-2011, 06:12 PM
A2theK's Avatar
Currently don't have a CEL so I figured I could see if I had any stored codes but I guess I don't. Wouldn't a bad O2 sensor give me any type of code? Not seeing any leaks either.
Old 12-28-2011, 07:56 PM
alltracman78's Avatar
OBD I diagnostics aren't that sensitive, it's usually only going to give you a code if something is BROKE.
Old 12-29-2011, 01:17 AM
TNRabbit's Avatar
Concur. Never had a CEL from O2 sensor on these older model vehicles.
Old 12-29-2011, 02:11 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I have. On my '86 22re, I had a code 5 I tried to trace down for a long time. Turned out the AFM was going south. Otherwise, I've never had an O2 code from anything else. Even from a vacuum leak. If you're O2 was to become disconnected, though, that would certainly cause one.
Old 12-29-2011, 08:42 AM
abecedarian's Avatar
if you put the clip in and it just flashes "on-off-on-off-on-off" ad infinitum, you don't have any stored codes.
why are you asking, A2theK?
Rerun
3.4 Swaps
10-01-2015 12:24 PM
bradahman
10-01-2015 09:24 AM
Boomer8404
09-24-2015 01:12 PM
Kylenicoll33
09-24-2015 12:13 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: ECU Self-Diagnosis (Paper Clip)
