ECU Power Supply
Old 08-24-2008, 06:58 PM
ADH8796's Avatar
ECU Power Supply
Well I've been working on my 85 that now has an 87 22RE in it. When I start it up it runs fine until I put it under load and then it sputters and well it's just not pretty. I found this http://autorepair.about.com/library/...bl-dtcs-36.htm so I went ahead and ran the test and came up with 11 blinks of the check engine light indicating something is wrong with my ECU Power Supply. Well now I know what seems to be causing my problems but I don't know what I need to do to fix it. Someone help me out and shine a little light on this for me. Thanks!
Anthony
Old 08-24-2008, 07:05 PM
abecedarian's Avatar
what I have shows code 11 for '85-'87 is a switch problem, either a/c or throttle position sensor, or a problem with the ecu. I'd check the throttle position sensor first.
Old 08-24-2008, 07:06 PM
did you transfer the entire 87 harness and ecu to the 85, or are you using the 85 computer with the 87?
*edit- actually, it shouldn't matter, unless the 85 was carbureted....
Old 08-24-2008, 07:10 PM
ADH8796's Avatar
When it comes to this stuff I don't know crap. How do I check throttle position sensor?
Old 08-25-2008, 08:36 PM
colsoncj's Avatar
Sent ya the TPS check proceedures. Let me know how it turns out, or if ya need one...
FYI: Truck has an 87 motor, 87 harness, and 87 ECU. Also has the 87 Airbox lid with the 87 MAF, and the 87 exhaust manifold with the 87 O2 sensor... Pretty much the entire drivetrain, motor, tranny, t-case and electronic controls are all 87. The two were mated together at the 85 MAF sensor plug that was originally in the 85, and then where the 85 body harness plugs into the 87 ECU... IIRC those were the only two connection points. Well that and the Alternator lead.
Old 08-26-2008, 07:42 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Anthony
What makes the difference here in interepreting the code 11 is whether it's a single digit code or a two digit code. Eleven blinks consecutively is a single digit...which would mean what Abe has pointed out. And, the two digit...once, then slight pause, then once again.... points directly at power supply to the ECU.
Some people have found if it is a TPS problem that by unplugging it the condition improves as there is no longer a sensor malfunctioning in the circuit sending erroneous info to the ECU. Then, by default, the ECU adjusts and compensates. So, you might try that as a quick way to pinpoint it. Then, of course, test it to verify what's actually wrong with it. But, it sounds to me like the VTA (throttle angle) circuit is bad in the sensor.
By running a "sweep test" not covered in the standard testing procedures, you can find out.....that is if you find everything looks good with the standard test. Basically, hook the positive probe to the VTA terminal and the negative to the E2 terminal. Then, slowly and gradually move the throttle plate open while watching the meter. It should move upward in resistance without faltering.
Old 08-27-2008, 04:21 AM
colsoncj's Avatar
Anthony... I didnt get a chance to email you those testing proceedures, but check out the FAQ/Links post in Ozarks... Somewhere in it is the link for a Factory Service Manual for an 85... Open it and check out the EFI Diagnostic portion and you'll find the testing proceedures. I'd email it to ya now, but the work firewall doesnt seem to like me.
Old 08-27-2008, 08:34 AM
ADH8796's Avatar
The first Code I pulled was a two digit code 2 blinks then pause folled by 9 consecutive blinks. I put a new TPS on it and that didn't help any so I'm going to say that's not my problem. I'm not sure what to do from here. I might just take it to the shop and leave it to someone who know's what they are doing (hate to do it but oh well).
Old 08-27-2008, 09:11 AM
4Crawler's Avatar
Did you test the old or new TPS and did you adjust the new TPS properly after installing it?
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old 08-27-2008, 10:33 AM
colsoncj's Avatar
Two blinks, then a pause then 9 blinks may be 2 seperate codes, a code 2 and a code 9. that or a code 29.... I'm working on pulling up an FSM to check out what those codes are.
Old 08-27-2008, 10:36 AM
4Crawler's Avatar
I have the early and late model trouble codes listed on the web page below:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old 08-27-2008, 10:57 AM
colsoncj's Avatar
Anthony, how long was the pause between the 2 and 9 blinks?
Roger, my work firewall is blocking your site Is there a code 2, 9, or 29 for an 87? All I can get access to is an 85 and a 88 FSM.
Old 08-27-2008, 11:38 AM
ADH8796's Avatar
maybe a second or so
Old 08-27-2008, 11:40 AM
4Crawler's Avatar
Should be in one of those two books.
'85:
Later '80s/90s models:
http://www.off-road.com/toyota/tech/codes/index.html
Old 08-27-2008, 12:28 PM
ADH8796's Avatar
just checked my blinks again and it's 11 consecutive with no pause
Old 08-27-2008, 12:40 PM
ADH8796's Avatar
I'm getting ready to check and see if I have power going to the ECU and I'll let you know what I find out
Old 08-27-2008, 06:01 PM
ADH8796's Avatar
It's going to the shop tomorrow
Old 08-27-2008, 06:27 PM
thook's Avatar
Were I in town, I'd be happy to help you out. It's probably something real simple. If you don't have a regular place you go, Fayetteville Foreign Auto (or Car?) is a good place. Brain Holly's a friend of mine.
Old 08-27-2008, 07:28 PM
colsoncj's Avatar
Matthew... if you could help, that would be awesome... I could cover the cost of your parts and just have ya cover shipping if ya could! Anthony is a good friend and I wish I could help more readily, but I'm too far so I'm not too much help!
Old 08-27-2008, 07:44 PM
ADH8796's Avatar
Matthew...I live right off hwy16 in fayetteville if you know where that's is. If you take 265 West until it ends and then take a left on hwy16(huntsville rd) I'm about a mile down on the left. If you could give me a hand that would be cool and if not I'm just going to take it in and hope it's something simple and fairly cheap. Thanks!
Quick Reply: ECU Power Supply
