early 1995 4runner v6 swallowed water need help please!!!
Old 06-08-2009, 09:34 AM
sunken4runner's Avatar
i got a early 1995 4runner has 3.0 v6 4x4 ran it through a deep hole sucked up water in the intake and it hydro locked the motor i got it home pulled all the plugs pumped out the water put them back in and started it and it was runnin like crap and only on 4 cylinders, so i pulled the covers and timing belt and it was off so i put everything back on there marks (top 2 cams on the marks on the back cover and the crank on the "0" mark on the timing cover) and now if you give it just a little bit of gas and hold it there it runs good and if you slowly give it gas it stays smooth, but if you gas it hard it spits and sputters and it doesnt want to idle and when it gets hot it doesnt want to crank???? there is no water in the oil???????? any ideas? could i still have the timing off????
Old 06-08-2009, 10:00 AM
Staff
DeathCougar's Avatar
Likely bent a rod
Old 06-08-2009, 08:34 PM
but all cylinders have good compression????????
Old 06-08-2009, 09:26 PM
gary96360's Avatar
wet wires, water in the distributor
Old 06-08-2009, 09:31 PM
no water in the dizzy everything has dried out goin to get new plugs and see what happens
Old 06-10-2009, 08:18 AM
sooooooo the problem was my maf i walked into my shop and saw an old intake and maf assembly on the ground and it just clicked in my head....too much gas??? black smoke and gas smell???? i figure i shorted the thing out but o well thanx anyways for the suggestions
ladybugRC
458
08-21-2020 10:41 AM
83yotastockR
11
11-10-2015 06:54 AM
dzldust
7
10-06-2015 05:39 AM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: early 1995 4runner v6 swallowed water need help please!!!
