E-brake solution to rear disk swap??
I really like the full floater.
But if your using a line lock then it's really not an e-brake just a parking brake. I ripped a brake line out on a trail and was thankful for the e-brake through it doesn't brake very good. Line locks won't work without brake fluid and brake depressed to set.
There are two types of line locks mechanical and electrical. Mechanical ones shouldn't drain battery but gotta run lines to mount it into the cab.
FJ Cruiser rear disc/drum conversion
Crossreference for rear disc/drum components.(According to Rock Auto)
You will probably need to use IFS hubs, but I cannot confirm this yet.
It appears that all
found on these models:
(note: hub hole for rotors may not fit older 108mm hubs)
LEXUS GX470 (2003 - 2009)
TOYOTA 4RUNNER (2003 - 2009)
TOYOTA FJ CRUISER (2007 - 2009)
TOYOTA SEQUOIA (2001 - 2007)
Rotors with Hub hole @ 108mm as found on older Models with SFA and IFS
LEXUS GX460 (2010 - 2014)
TOYOTA 4RUNNER (2010 - 2014)
TOYOTA FJ CRUISER (2010 - 2014)
Calipers:
LEXUS GX460 (2010 - 2013)
LEXUS LX450 (1996 - 1997)
TOYOTA LANDCRUISER (1993 - 1997)
It appears that all
Calipers:
1 Post
good point on it being a parking brake and not an -e brake. You mentioned you had a chain drive case, what's stopping you from using a t-case mounted brake? Do they not make one?
No, chain drive, gear driven t-cases.
I'll compare cost when a disc conversion that uses stock parking brake comes out.
I had gotten a conversion kit hadn't installed before being stationed in Germany. So truck went to storage at father in laws. Parts went in storage through a storage company but several things came up missing after: disc conversion kit, FSM, 3/4 inch socket set......
Just weighing options, again.
#25
I like my disc brake conversion. I also like my tcase ebrake. However, I sure would like to have a rear disc ebrake though because of the possiblities of one tire slipping and causing the truck to move......
#26
It appears that all
Calipers:
It appears that all
Calipers:
Just updating some part info.
jerusry
10-19-2015 05:28 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
icentropy
07-09-2015 02:12 PM
