Drivetrain vibration question
Old 07-28-2009, 09:09 PM
Willie B's Avatar
I have an 88 4runner, and can't figure what is causing the vibration I am getting. I am getting a vibration when I am accelerating, basically when I am sending power through the drivetrain. I feel it most in first and second, when I am taking off from a stop. It feels like a vibration that is matching up with the rotation of the driveshaft. The instant I push in the clutch, and coast, the vibration disapears, and is is smooth. I changed the rear u-joint, and the front ones are tight. There doesn't seem to be any play in the pinion either. Any ideas what to check next?
Old 07-28-2009, 09:17 PM
myyota's Avatar
Check your u joints, if there bad you will get a vibration.
Old 07-28-2009, 09:29 PM
Willie B's Avatar
I replaced the rear 2 weeks aago, and the fronts are tight. Can't figure it out?
Old 07-28-2009, 09:42 PM
myyota's Avatar
Try checking the front and rear wheel bearings, i had to replace the rear wheel bearing on my 4Runner a few months ago, they were so bad that i could wiggle the center part of the bearing almost a 1/4'' , and when the solid axle was put in the front i rebuilt it also with all new bearings and seals.
Old 07-29-2009, 05:43 PM
hindsight2020's Avatar
my drive train is also vibrating. so bad that it vibrated my left side exhaust pipe from the manifold.
Old 08-06-2009, 10:54 AM
Willie B's Avatar
O.K. I climbed under the Runner once again shaking around on stuff. Every joint in the driveshaft is tight. I grabbed on the drive shaft in the middle where the two halves slide on the splines. I wiggled it, and there is a slight amount of play side to side in the drive shaft slip splines themselves. Not much but a tiny bit. Could this be causing some of the vibration? Like I said, it is only really felt under a load as slow speeds, 1st and 2nd when I get the vibration. When the clutch is pushed in it is smooth.
Old 08-06-2009, 11:02 AM
fillsrunner4's Avatar
could be the tranies main bearing going bad. its a 5spd right? Just another place it could be coming from
Old 08-06-2009, 11:04 AM
You by chance have a slight leak coming from the bellohousing area?
Old 08-06-2009, 11:12 AM
BlueRidge's Avatar
Is your pinon angle correct and in phase?
Old 08-06-2009, 11:20 AM
grant526's Avatar
Sounds like it's probably your clutch slipping, Jumping and Chattering. . .
I believe Fillsrunner4 is suggesting your clutch may have Oil on it. If your rear main and/or transmission front seal are shot.
If you think it's in the rear driveline, take it out. Put the truck in 4hi and drive the truck in "fwd." If You still have the issue, you've eliminated the rear driveline and u-joints.
Keep us posted.
Good Luck,
Grant
Old 08-06-2009, 11:22 AM
Willie B's Avatar
No leaking comming from the bell housing area, and the transfercase bearing seems tight.
As for th pinion angle, I have a 4 inch lift, and there is I think about a 3- 3.5 inch block in the back, that is tapered, BUT my springs are friggin' sagged flat. I bet my rear is probably only 1 or so inchs above stock height. Could be casusing the pinion angle to pint up to much. Visually though it does not look out of whack.
Old 08-06-2009, 01:07 PM
muddpigg's Avatar
Read 4crawlers website's explaination of Dline angle then measure it.
Old 08-06-2009, 01:50 PM
Willie B's Avatar
Thanks bud will do!
Old 08-08-2009, 05:34 PM
sh0kk86's Avatar
I replaced my rear main seal/clutch/flywheel/TO/pilot bearings a while back.
shortly after i had a leak from the bottom of the bell housing area/slave cylinder boot.
dropped teh tranny again, and it wasnt coming from the rear main. so i replaced the input seal and it still leaks,. ive just been driving on it but what could it mean? input shaft worn? tranny bearing going bad? 190k on stock g52 trans
justdifferentials
Just Differentials
09-17-2015 06:14 PM
lectric80
08-11-2015 12:02 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
MTLroadierunner
07-20-2015 03:07 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: Drivetrain vibration question
