Driveshaft Delima
Old 04-01-2009, 11:34 PM
94exblack's Avatar
Driveshaft Delima
I was wondering if anyone has had any experience with trying to lower the carrier bearing, to get more out of a factory driveshaft, just dont want to spend an extra 3 or 4 hundred buck if i dont have to.
Old 04-01-2009, 11:50 PM
algranger's Avatar
Not sure what your asking here
Old 04-02-2009, 12:50 AM
totally a bro
Staff
vital22re's Avatar
longer bolts and a bunch of washers! or make a spacer plate and use longer bolts. I'm doin the same to mine soon, i'll let you know what i do if i finish first.
Old 04-02-2009, 02:00 AM
razrwild's Avatar
spacer plates and washers work just fine.
Old 04-02-2009, 05:00 AM
Hypoid's Avatar
I don't know how far you can drop it without significantly misaligning the carrier. Try to keep the shaft pointed at the tcase.
Old 04-02-2009, 05:38 AM
mt_goat's Avatar
I had to raise mine after I put on dual cases to reduce the angle a little. I flipped the bearing to the top of the bracket and used some washers. It's covered here on pages 11 & 12: https://www.yotatech.com/forums/f160...5/index11.html
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
ToyotaMD
08-17-2018 10:16 PM
Hugh_Mann
09-16-2015 03:59 AM
Quick Reply: Driveshaft Delima
