Which drive train do I have???
Old 10-14-2010, 07:00 PM
Phessor's Avatar
I have a 1989 pickup with a 22RE and an automatic and a transfer case with its own oil pan.
I am looking to drain and replace the filter but I do not know how much ATF to put back in it.
What do I have?
Anyone have any ideas?
Thank you, Phessor
Old 10-14-2010, 09:04 PM
mmcpeck's Avatar
Are you looking to drain and re-fill the tranny or Xfer case?
Old 10-14-2010, 09:08 PM
Phessor's Avatar
It has a leak at the transmission pan so I figured I would drain and replace the filter while I was at it.
I just wanted to make sure I got the right filter, pan gasket and enough ATF fluid before I started.
Phessor
Old 10-15-2010, 04:18 AM
Hadmatt54's Avatar
You mentioned the separate pan on the transfer case, you should also see that the transfercase is not removable and that there are hydraulic lines coming out the back. If that is what you are looking at then:-
Your transmission is a A340H.
Old 10-15-2010, 04:48 AM
ScottyC's Avatar
The tranny and Tcase share the same fluid. They would have called for Dexron II, so any Dexron equivalent replacement is what you will want to use.
Old 10-15-2010, 05:11 AM
rustypigeon's Avatar
If you look at the sticker in your driver side door jamb, it will tell you what transmission you have.
Old 10-15-2010, 07:37 AM
angrydogtattoo's Avatar
+1 on the A340H if they have separate pans, if there is only one pan then its an A340F. Transfer has gear oil, trans has Dex II
jasonty
41
12-23-2018 01:00 PM
Tykiller1994
08-10-2015 07:49 PM
kyletbert
07-17-2015 11:39 AM
Poncho0206
07-10-2015 06:21 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Which drive train do I have???
