DOOR PANNEL REMOVEL (Please Help!!)
Old 02-25-2008, 10:39 AM
keithguts's Avatar
Im trying to take the door pannel off to put a new window motor in. I got it all ready to take off, but the dood handle will not come off for me to get it off. How does this handle come off. PLEASE HELP!!
It is a 95 4runner
Old 02-25-2008, 10:44 AM
Blurr's Avatar
remove the single phillips screw then you need to slide the handle assembly towards the front of the vehicle about 1/2inch. after that you need to disconnect the long metal arm that attaches the handle assembly to the door latch.
Scooby098's Avatar
well mines held on by a c clip. just use a piece of cloth and put it under the door and pull up it should just pop out
Old 02-25-2008, 10:46 AM
dirtoyboy's Avatar
a FSM would help you in more way than one! check em out!
Old 02-25-2008, 12:10 PM
aviator's Avatar
Like Blur said remove the phillips screw and slide the handle assembly forward, it is very stiff and may take a firm but gentle tap on the back with the butt of a screwdriver to get it to come loose. Assuming you've removed the control cover and disconnected the controls and removed the screws and armrest assembly, carefully pry the panel off around the edges and lift it up to free the top edge rotate the panel 90* and the door handle will come out through the hole you don't need to take the handle off the metal control arm at all. Putting the thing back on is a simple reverse process.
Old 02-25-2008, 12:15 PM
Blurr's Avatar
good call! i could have used this trick a while ago when i started mounting my door speakers
Old 02-25-2008, 08:26 PM
shancerlelby's Avatar
just start prying on things and break stuff, thats how you learn don't worry so much.
"remove the single phillips screw then you need to slide the handle assembly towards the front of the vehicle about 1/2inch. after that you need to disconnect the long metal arm that attaches the handle assembly to the door latch." thats exactly how i'd discribe it too.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
JamesDINAN
09-22-2015 05:37 AM
Quick Reply: DOOR PANNEL REMOVEL (Please Help!!)
