DOOR PANNEL REMOVEL (Please Help!!)
Im trying to take the door pannel off to put a new window motor in. I got it all ready to take off, but the dood handle will not come off for me to get it off. How does this handle come off. PLEASE HELP!!
It is a 95 4runner |
remove the single phillips screw then you need to slide the handle assembly towards the front of the vehicle about 1/2inch. after that you need to disconnect the long metal arm that attaches the handle assembly to the door latch.
well mines held on by a c clip. just use a piece of cloth and put it under the door and pull up it should just pop out
a FSM would help you in more way than one! check em out!
Like Blur said remove the phillips screw and slide the handle assembly forward, it is very stiff and may take a firm but gentle tap on the back with the butt of a screwdriver to get it to come loose. Assuming you've removed the control cover and disconnected the controls and removed the screws and armrest assembly, carefully pry the panel off around the edges and lift it up to free the top edge rotate the panel 90* and the door handle will come out through the hole you don't need to take the handle off the metal control arm at all. Putting the thing back on is a simple reverse process.
Originally Posted by aviator
(Post 50761784)
just start prying on things and break stuff, thats how you learn :P don't worry so much. :D
"remove the single phillips screw then you need to slide the handle assembly towards the front of the vehicle about 1/2inch. after that you need to disconnect the long metal arm that attaches the handle assembly to the door latch." thats exactly how i'd discribe it too. |
