Does not fit models with automatic transmission
Old 08-30-2009, 11:42 AM
xwing777's Avatar
Why do i always have the odd stuff. I have a 91 truck with auto trans and can not find a 1"-3" lift kit anywhere as it always says "Does not fit models with automatic transmission"
Does anyone know if anyone, anywhere makes something to work?
Old 08-30-2009, 11:56 AM
myyota's Avatar
Its because the shift linkage will be to short if you do a body lift, if you were able to custom fab some new shift linkage then you could do a body lift.
Old 08-30-2009, 11:58 AM
woodendude's Avatar
4 crawler sells the extention required for an automatic body lift.
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
Old 08-30-2009, 12:24 PM
xwing777's Avatar
Thanks you, i could never find anyone that offered kits for autos. Has anyone used their 2" kits on an auto?
Old 08-30-2009, 01:15 PM
SpecialScottie's Avatar
I have a 3 inch on my 85 with an auto and I didnt need to do anything to the shifter
Old 08-30-2009, 02:32 PM
1990mudslut's Avatar
I have a 1990 ext cab yota with an auto and the 4crawler 3inch body lift.I love it,however it was a little time consuming but otherwise.Read through 4crawlers site he will tell you what all you need for your body lift and ill post up what all I needed to do mine.
I needed:
3 inch radiator drop brackets
Steering extension
Automatic shift linkage
Bumper brackets
I also bought the heavy duty hardware and new body mount bushings but they wasn't needed.
Good luck to you.
Old 08-30-2009, 03:35 PM
xwing777's Avatar
Thanks for the info. I have factory bumpers and a trailer hitch (curt if i remember correctly) Will the hitch need modification as well?
I use this truck for towing and can not loose the hitch.
Old 08-30-2009, 05:57 PM
if you are talking about a hitch that is attached to the frame no you won't need any modifications however it will no longer sit right below the truck.
BeMiceElf
10-10-2015 09:40 PM
Poncho0206
07-10-2015 06:21 PM
shar
07-09-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Does not fit models with automatic transmission
