Does anyone know of a 22re bolt kit?
I'm trying to put my 22re back together and all of the 20+ year old bolts are snapping at torque values that should not snap them. Does anyone sell a new bolt set for 22re? Another question is does anyone know of a print/ parts list that has a listing of 22re bolts including tread pitch, diameter and length?
http://www.22re.com/main/toy/toy.asp
This place has the bolt set, you just have to scroll down a bit. The only place I know of to see the lenghts of the bolts is on 4crawler's site. He has a write up for changing the timing chain and one of the pictures has all the lenghts.
if you have the space and plan to keep working on Toyotas
It would pay to get a bolt assortment in M8x1.25 M10x1.25 and M12x1.25 and the nuts as well. JIS rather then DIN i get mine from Pointe Products
Then as needed you can get the special ones like banjo Bolts the long alternator bolts etc.
You drop one the last owner rounded one off so much easier to just have the correct one at hand . Toyota is not all that expensive on most of the hardware either
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
