Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
does 22r head = 22re head
Have 1990 s/b truck with 22re. timing chain seems to have slipped a tooth, i.e. bent valves. I have a 22r head. Is it the same as the 22re?
Thanks eh, Me |
| Sponsored Links |
#2 (permalink) |
should be......i think.
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Mellowtone Muffler AISIN Manual Hubs, Marlin Crawler Sliders 181XXX miles 92 Ford Ranger 4x2 4.0L 4 speed auto FOR SALE Needs Transmission And Head gasket work. Contact me for Details. "An Open Mind is Like a Fortress with its Gates Unbarred and Ungaurded." "There are two kinds of people in this world that go around beardless: boys and women, and I am neither one." -Greek saying |
#4 (permalink) |
They are the same for your truck. I think '84 and older 22R heads are different.
They did change something on the EFI in '89 - 95 ... Dont know what exactly but i dont think it was the heads, someone clarify?
__________________
1987 Toyota P/U 4x4 pics/info |
#5 (permalink) |
22r head isn't necessarily the same as a 22RE head.
Do you know the year of the 22r head?
__________________
http://www.22REturbo.net |
#6 (permalink) |
22re and R heads are NOT all the same. On older motors like the 22r you need to use the celica efi manifold. Watch the stud pattern on the manifolds to make sure it will work. If you do the swap of the heads and need that celica manifold i have one. I also have 2 22r heads a 22re head and a built 20r head.
__________________
87 longbed on 36's*now with scrubbing bubbles* 86 SR5 2wd-soon to be laying frame under the 87. |
#7 (permalink) |
Head year request
The 22r head is from a 1989 sb truck. I used the chassis to build the rig I have now. Mahalo guys, Me
#8 (permalink) |
85-95 22r and 22re heads ARE the same. 84 and back is a different story.
#9 (permalink) |
Thanks guys for all your opinions and the good ideas. Will most likely pull the 89 head tomorrow and take it to the machine shop Monday. Then start on the truck. Like Frankie its made from dead parts! Me
#10 (permalink) | |
Quote:
James
__________________
2nd gen power mirrors for sale http://www.yotatech.com/f109/2nd-gen.../#post50746877 New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569 Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/ |
#11 (permalink) |
all 22re heads i seen just have a plate. do you recall what ones don't ?
__________________
Dan 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd |
#12 (permalink) | |
Quote:
for the sake of a swap, 85-95 are the same. a 22RE is a 22R with fuel injection, a lot of guys forget that. the only place it would come into play is if you were looking for an early style head, the 22RE didn't appear until 1983, so if you picked up an '81 or '82 head it wouldn't have the bosses for the EFI manifold.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#13 (permalink) | |
Quote:
James
__________________
#14 (permalink) |
I'am wrong:pat: I just looked and it has a block off plate. I was thinking of the 3RZ-FE motor in my mothers 03 Tacoma that I was working on the other day. It had a boss for the earlier distributors and that is what was in my head. My bad.
James
__________________
#15 (permalink) |
__________________
1987 DLX 4X4 5 Speed: Electric Flex-a-Lite,SR5 guages,Yokohama Geolander A/T+ II,Pro Comp AAL, KC Slimlites, Bull Bar, Aux fuse box, Limo Tint, Marlin Crawler Bumper, painted shell, Sirius Wish List: Safari Rack,Bigger tires, SDORI BJ Spacers, 2001 Limited 4X4 Auto:Tundra 231mm brake upgrade, Brembo Rotors, Akebono Pads, 17" 2007 4Runner wheels, Yokohama Geolander AT-S,Sirius & Limo tint Wish List: TJM Front Bumper, KC Hilites, Safari Roof Rack, Thule Cargo Box, Rock sliders, Limo Tint |
#16 (permalink) |
Something FYI, Watch out for the bolt in the front of the head under the distributor gear, a pool of oil covered mine (I didn't know it was there). When I loosened the head the t-chain cover broke. #$%$%#% A bunch of thanks for all your input folks!!! Yep, the t-chain did jump. At 150k miles not unheard of. There was also alot of carbonization around the starboard side head bolt behind #3 and the bolt hole. I had been loosing coolant very slowly lately, none in the crankcase. Guess we know where it was going now, eh. Since the rig has so many miles on it. I've decided to pull the block and have it built too. Appreciate all the discussion. Me
#17 (permalink) |
Agreed, 1985 and newer 22R heads are the same as 22RE's. The '84 and older 22R heads have a different shape exhaust ports and slightly different mounting holes for the exhaust manifold. I believe the only "difference" in the head is the cam shaft. I have used 22R heads on 22RE's, and vice versa (including camshafts, and it has always worked. Don't forget to get new headbolts. You can technically reuse them, it's not worth it especially if you were already suspecting headgasket issues.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22R = 22RE Head studs? | Bill | 86-95 Trucks & 4Runners | 1 | 01-18-2007 06:31 PM |
| 85 22re block with brand new 22r head | 4bytruckin | Engine/Tranny/Parts | 3 | 10-04-2006 01:51 PM |
| 20R with 22R head on a 22RE? | Amir904 | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 06-23-2006 07:24 PM |
| 22r/22re head interchangeable ?? | Mr.Spock | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-04-2003 10:29 AM |
| 22RE and 22R Head swap...compatible years? | Mudd Runna | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-13-2003 06:53 PM |
