distributor issue
Old Jan 31, 2007 | 08:16 PM
old4runner's Avatar
distributor issue
i just got done replacing my timing chain and i am trying to re-install my distributor and it won't go in past the o-ring...does anyone have any ideas. it is an 87 22re thanks i appreciate everyones help this site has saved me a lot of headaches
Old Jan 31, 2007 | 08:21 PM
DeathCougar's Avatar
turn the gear just a bit. DONT try to jam it in, or you will damage the gears. the 22r has a sort of "in between" where the dist will sit down just a bit, but not go int. Make sure the engine is at TDC, and the rotor is pointed at #1 on the cap. It should be perfectly on to line up correctly.
Old Jan 31, 2007 | 08:29 PM
old4runner's Avatar
how far past the o ring is the inbetween
Old Jan 31, 2007 | 08:36 PM
you're hitting the in between right now, hence why the distributor wont sit down right. Try turning that gear just a bit to get it to pop down
Old Jan 31, 2007 | 08:51 PM
old4runner's Avatar
i tried that for about 20 minutes, but to no avail....the rotor will turn when i turn the crank so it is partially engaging but i have a full centimeter gap between the distributor and the block
Old Jan 31, 2007 | 09:24 PM
hmm, well, it should sit down all the way then. Try taking your valve cover off, and making sure it is engaging the gears properly.
Old Jan 31, 2007 | 11:04 PM
the_supernerd's Avatar
Make sure you re-assembled everything on the cam properly and torqued down the bolt. If something is off a little, then the distributor drive gear will be too far forward and not line up correctly.
Old Feb 1, 2007 | 04:17 PM
old4runner's Avatar
i got it, thanks fellas
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
smiley52
Jul 11, 2015 05:16 AM
