Discovered rust / Repair questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-16-2007, 06:07 AM   #1 (permalink)
Well this weekend I finally got around to removing the stock chrome bumper on my '95 4Runner that was heavily rusted through. Even with copious amounts of PB blaster, i still snapped the heads off of 4-5 bolts, but the bumper came off. when i got it off, i found this on the passenger side behind the rear wheel:
needless to say, i was not happy. this was all hiding behind the side pieces and i had no idea it was back there. interestingly, the drivers side is absolutely fine. i haven't taken it to a body shop, but i'd expect the estimate to be in the low thousands. i'm contemplating attempting this repair myself with the help of my friend who has a TIG welder. i browsed on the web briefly and came across this page where patch panels are sold:
http://www.alfaparts.net/toyota4r.htm
i searched around this site, and found some other rust threads, but none that touched on this area or that vendor. i would think this would be a common area for rust as there is no accident damage back there to bring on this type of rust on a '95. this truck has also lived all of it's life in VA, where the winters aren't that bad and i don't live by the ocean.
__________________
James
'95 4Runner V6
jht3 is offline
Old 07-16-2007, 06:14 AM   #2 (permalink)
4RocRunner92's Avatar
Send a message via AIM to 4RocRunner92 Send a message via MSN to 4RocRunner92 Send a message via Skype™ to 4RocRunner92
Go to http://www.nc4x4.com/forums
def find what you need there.
for CHEAP
__________________
Jason
A friend of the devil is a friend of mine.
1992 SR5
4RocNC
Videos
4RocRunner92 is offline
Old 07-16-2007, 07:14 AM   #3 (permalink)
slacker's Avatar
metal repair .. and fit awesome , much better the the press brake stuff from wolf , but then it is a little mor expencive .
http://www.toyotafiberglass.com
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5 CURRENT BUILD
My home page MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 07-16-2007, 07:17 AM   #4 (permalink)
saw that site, howerver, those arches don't extend back far enough to eliminate the rust that i have. you've seen the wolf parts and they are not good? i don't think that matters much as all the rust is on the lower quarter, which already looks like ▓▓▓▓ w/ a tube bumper mounted
__________________
James
'95 4Runner V6
jht3 is offline
Old 07-16-2007, 07:19 AM   #5 (permalink)
for CHEAP
thanks for the link, but what am i looking for and where?
__________________
James
'95 4Runner V6
jht3 is offline
Old 07-16-2007, 09:18 AM   #6 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
you may just have to make your own patch panel out of 16 gauge sheet metal. you will also need to try and get behind it and treat it with some sort of sealer or anti rust. there is a spray wax that works ok, but i'd use an epoxy sealer such as ppg dp90 or even a good undercoat.
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 07-16-2007, 10:54 AM   #7 (permalink)
why 16ga? i'm new to this type of repair so pardon the "dumb" questions
there's no problem getting behind there, as i can already get most my hand up there. to fix it, i envision i'd have to cut along the pinch welds, then up and across the sheet metal, leaving a huge clean opening. there are some complex curves and bends at this area, so that's why i was hoping to find a patch panel as i don't have access to real metal working tools. a small shear, grinders, and TIG are about all i have (race car fab shop stuff).
__________________
James
'95 4Runner V6
jht3 is offline
Old 07-24-2007, 06:35 PM   #8 (permalink)
DudeBud's Avatar
you can use whatever ga sheet metal you have... you have an easy fix. may even want to go see if you can find a quarter at a wreaking yard that they could cut a section for you.
__________________
Dan
95 4runner 3vze A/T
37X13.00 boggers
DudeBud is offline
Old 07-24-2007, 06:52 PM   #9 (permalink)
mtsumedi's Avatar
Isn't that part covered by the chrome bumper piece anyways? Just remove the rust that is there and prevent anymore rust from occurring and then put another bumper piece back on. You can find them on Ebay.
__________________
1993 4Runner SR5 4x4
1995 Avalon XLS
1999 Coleman Bayside Pop Up Camper 2,700lbs 8-O
mtsumedi is offline
Old 07-24-2007, 07:12 PM   #10 (permalink)
drock2's Avatar
Send a message via AIM to drock2
I stumbled upon the same rust damage on my 95 Runner a couple of weekends ago. It was sure disappointing... Unfortunately I didn't have access to a welder so I went to Advanced Auto and purchased some sheets of wire body mesh and a big thing of bondo. First I cleaned up the area with a wire wheel, then applied a thick coat of Por-15. After that I bent the mesh in the shape of the hole and stuck it on. Lots of bondo, sanding, more bondo, sanding, sanding, some primer and gloss black paint later and it turned out well. Now I’ll just have to see how long it will last?
__________________
1995 Toyota 4Runner SR5 4x4 - Tjm Front Bumper, Kennesaw Mountain Accessory Rear Bumper, Downey Rear Coils and Torsion Bars (2" Lift), Rancho RS9000 Shocks w/ In Cab Kit, BF Goodrich 33"x10.5" MT's, K&N CAI, Magnaflow Muffler, Sony Xplod Head Unit, Rockford Fosgate Speakers, Alpine 250W Amp and 10" Sub, Uniden CB, Hella FF300 Light Kit, Warn M8000 Winch, Surco Roof Rack, Aisin Manual Locking Hubs
Dominic
drock2 is offline
Old 07-24-2007, 08:10 PM   #11 (permalink)
Send a message via AIM to Slednutjetskier Send a message via MSN to Slednutjetskier
I would think Certifit would be the cheapest for a full replacement and I have always had good luck with there panels and pieces for my Honda. Although it is true I have never put some on my Yota, I would vouch for good pieces and cheap prices.
www.certifit.com
Slednutjetskier is offline
Old 07-25-2007, 05:34 AM   #12 (permalink)
yes, this piece is behind the chrome side panel, which is why i never saw it. i now have a marlin rear bumper so this area is always be exposed. i don't care about looks, just that it's fixed the right way.
i still haven't taken it anywhere to get a quote, so depending on that, i'll either pay up or dig in and tackle this myself (with the help of some more skilled friends)
i also have found the beginnings of rust behind the plastic caps at the front of the rear wheel wells and along the lower seam of the passenger front door. argh. those areas i can probably hit w/ a wire wheel, primer, and repaint
__________________
James
'95 4Runner V6
jht3 is offline
Old 07-25-2007, 09:49 AM   #13 (permalink)
well i took off the chrome arch surrounds and lower plastic cover and found my biggest fear....MORE RUST. i can push a screwdriver through the entire lower "dogleg" area
argh
__________________
James
'95 4Runner V6
jht3 is offline
Old 07-25-2007, 07:30 PM   #14 (permalink)
82yota's Avatar
Well once you get it fixed make sure not to cover that area with anything again. Whereever there is plastic covering metal it will rust. If you have fender flares there will be rust under them. First thing to do with a nice clean truck no rust is take all the chrome stripping off as the salt and sand gets behind there and eats it out fast.
82yota is offline
Old 07-26-2007, 05:25 AM   #15 (permalink)
don't worry. it's all stripped off and not going back on. if i could find my memory card, i'd put some more pics up
__________________
James
'95 4Runner V6
jht3 is offline
Tags
4runner, 4x4, coleman, discovered, dogleg, metal, panels, patch, pop, repair, rust, sheet, toyota, wheel, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
massive frame rust repair!! millertime_t1 The Fab Shop 20 11-18-2008 01:52 PM
Rust repair panels?? Flash319 86-95 Trucks & 4Runners 14 06-15-2007 10:03 PM
question about rust repair and prevention isaac338 86-95 Trucks & 4Runners 1 08-20-2006 08:33 PM
Rust Repair grams72 95.5-2004 Tacomas & 96-2002 4Runners 3 06-10-2004 06:39 PM
Rust spot repair tystoy 95.5-2004 Tacomas & 96-2002 4Runners 5 06-23-2003 09:55 AM
2009 InternetBrands, Inc.
