Diff breather part. online source?
Old Nov 24, 2007 | 07:15 AM
frozenSurf's Avatar
Question Diff breather part. online source?
I'm looking for the Nissan part that everyone uses for the diff breather mod. Does anyone know of an online source? The parts stores around here just look at me like I have a third eye on my forehead when I try to explain what I want.
cheers,
frozen
Old Nov 24, 2007 | 07:33 AM
04 Rocko Taco's Avatar
4crawler.com has the part #, you can get it from a Nissan dealership, he also lists the ALL Toyota parts for the diff breather. You can source those from any dealerships, including those online. I ordered mine ( nipple and breather) for like $11 I think.
Old Nov 24, 2007 | 08:03 AM
olharleyman's Avatar
cheers,
frozen
If you don't want to use that part you can do like I did and just pop the one way releaf cap off and get some fule line and a couple claps and route the hose up to the top of the motor in the front then up to the fuel fill on the rear it works just as good but with out the extra parts.
Old Nov 24, 2007 | 08:34 PM
leebee's Avatar
iirc, steve150 (member?) had the part #'s listed on his build page. i picked mine up at the dealer, even got a good price!
lee
Old Nov 25, 2007 | 12:24 AM
dropzone's Avatar
Fossilized
4crawlers: http://www.4crawler.com/4x4/CheapTri...Proofing.shtml
Nissan differential breather part # 38323-C6010; cost around $4.50/ea.
Old Nov 25, 2007 | 10:55 AM
Jay351's Avatar
I didnt bother with the breather, I just ripped off the cap and attached a line to that. Have submerged it in water, no leaks. Routed it up behind my taillight.
Old Dec 28, 2007 | 03:20 PM
camo31_10.50's Avatar
once i attach a hose to the diff...and route it to where its going to be...what do i do then....does there need to be anything on the other end...or do i just leave it opened...is there some kind of cap that u guys are using or what..thanks in advance..i recently submerged my both of my axles ...do i NEED to replace my fluids...or should everything be ok...last time it happened...the front axle was submerged for around 20 mins ...(i had to wait on my friend to get there to pull me out)...the rear hasnt ever been under for more than about 30 seconds...lol..thanks once again
Ken,
Old Dec 28, 2007 | 03:31 PM
TORTIS's Avatar
not sure about the rear, but i would change the front. if the rear was totally submerged i would change to. whats 25 bucks compared to 500 for a rebuild.
Old Dec 28, 2007 | 03:45 PM
rocket's Avatar
Marlin has an Axle Breather Kit http://www.marlincrawler.com/htm/axles.htm
It's a little pricey but comes with everything you need.
Old Dec 29, 2007 | 10:47 PM
standardbyker88's Avatar
is this just for 4x4 guys along the same lines of (keep stuff out) snorkels and high exhaust? or is there any 2wd street benefits?
Old Dec 29, 2007 | 11:13 PM
Jay351's Avatar
its good because it will prevent your breather from getting clogged and pushing the gear oil past your seals
Old Feb 10, 2008 | 04:54 PM
MrArmyAnt's Avatar
Ok so I just bought 1/8" brass fittings that seem to fit perfectly. Hold to tube very well, hose clamp not really needed, and come with teflon tape already on the threads for 1.79 each at true value hardware. could also put it on an angled connector for tranny and transmission.
Old Feb 10, 2008 | 08:28 PM
bry-an's Avatar
did you guys tape your with teflon??? I just grabbed the breather plugs yesterday I havent got my hose yet though.... I guess teflon might be a good idea ... but Id worry about it loosening with bumps
Old Feb 10, 2008 | 09:07 PM
MrArmyAnt's Avatar
I guess in theory it could come off. But it came with it on it, and I'm lazy as hell. If it hadn't been on it already I'd agree with you more, cause I'm lazy. Now that it's already on it I'm going to say it seals better with it, so I don't have to take it off
Old Feb 11, 2008 | 04:51 AM
dirtoyboy's Avatar
trail gear sells one now that is similar to the arctic cat snowmobile breathers...
I have the nissan part and it works fine with some fuel hose and a filter
justdifferentials
14
Jun 11, 2017 08:36 PM
larrys93pickup
Sep 17, 2015 07:05 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
skouba
Sep 14, 2015 06:58 AM
zz_denis
Sep 6, 2015 03:43 PM
