Cruise control downshifting problem?
Old 02-15-2009, 07:22 AM
James Dean's Avatar
I have a 93 4Runner with the 3.slow, and we know they're not the greatest out on the freeway at 75-80. However my cruise control has started to down shift to 3rd all the time, not just on inclines. If I control the gas, it stays in overdrive (so I know the motor or tranny isn't the problem), but if I turn on the cc it downshifts to 3rd and screams over 4000rpm. I found some old post with the issue, with no solutions. Is there any newer info on a remedy?
Old 02-15-2009, 07:51 AM
GreyRunner90's Avatar
I hope someone has a solution because i have the exact same problem in my 90 4runner with the 3.0
Old 02-15-2009, 08:23 AM
Marc's Avatar
I did a search I came up with this.
https://www.yotatech.com/forums/f116...nd-gen-101020/
I'm about to do this to my 90 as well.
Old 02-15-2009, 09:20 AM
thanks Marc, ill have to give that a try in a few weeks when i'm back home with my 4runner.
Old 02-16-2009, 09:47 AM
qdude79's Avatar
Can't speak to the 3.0/auto setup, but my 22RE/A44d setup is the same. I assumed that it was intended, as the 22RE isn't the strongest, but mine goes into kickdown IMMEDIATELY when I hit the "accel" button. If I hit the throttle manually, it won't. I think it's meant to be that way. Also, one thing I noticed is that it is WAY more touchy to kickdown on mild freeway inclines when first starting out. After a few miles and completely warmed up, it's not as apt to do that. 2/100ths of a dollars worth...
Old 02-16-2009, 10:04 AM
mt_goat's Avatar
Mine did that new from the factory, the slightest little hill and out it came. It was disturbing to me because I was trying to hold the engine rpms down during the break-in period. I took it into the dealer and they claimed it was normal.
Funny thing since I put in a 3.4 it almost never does it (same cruise control).
Old 02-16-2009, 10:25 AM
Aircrwman's Avatar
now....what about that same problem plus cruise control kicking out when under load?
it seems that there are not many topics on this particular subject.
Old 02-16-2009, 11:44 AM
qdude79's Avatar
Haven't had a towing or steep grade situation with my cruise to test/experience this with my 'Runner, but my old El Camino would do that. Seemed like once the cruise couldn't "keep up," it would automatically shut off. Hmmm....
Old 02-16-2009, 01:22 PM
Aircrwman's Avatar
exactly my problem....
Liadrin
04-25-2022 02:54 PM
Liadrin
09-01-2015 06:44 AM
rushw
07-18-2015 01:46 PM
1994toyota
07-17-2015 03:03 AM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Cruise control downshifting problem?
