Cooling Hose @ back of Intake manafold!!!!
Old 08-12-2005, 07:20 AM
On a 3.0 out of a 91' runner. what is the best way to get this hose off? It is leaking, do i have to pull the whole air intake off??? I don't think that I hav enought room to get to the clamp!!
any ideas??
thanks guys
boo :alien:
Old 08-13-2005, 10:52 AM
Guest
94x4's Avatar
I'm sorry, you want to remove the what?
Old 08-13-2005, 06:51 PM
ChickenLover's Avatar
I would recommend taking the plenum off. That way you can knock out some much needed maintenance while you are at it (cleaning t-body, intake, and plenum as well as replacing the pcv valve). If you have leaky valve covers that would be a great time to replace 'em too.
Removing the plenum is not as bad as it looks. take off the egr and reed vavles as well as the 7th injector's fuel line. Unbolt the plenum and just flip it up and out of the way. There is no need to take off all of the vacuum lines. Once you've done it once or twice it becomes a non-issue.
steve miller
10-10-2015 01:40 AM
Avenged
07-09-2015 07:55 AM
skoti89
07-08-2015 12:05 AM
bryan34w
07-06-2015 05:53 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Cooling Hose @ back of Intake manafold!!!!
