Compression test and head gasktet quetion..
I have a small coolant leak somewhere and am loosing coolant. I also noticed (its winter) that I am getting vapor cloud out of my exhaust but I think that might be due to lack of smog equipment and the weather conditions.
I did a compression test and all 4 cyl came out between 160-170.
Oil is good with no milk. It was missing a lot more coolant than it should have been with no major obvious leaks(heater core leaks slightly). If it was leaking this much coolant through a head gasket it would have showed up on the compression test right?
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
