Cold start problems
Old Mar 13, 2006 | 03:34 PM
NB4runner's Avatar
Cold start problems
I had my motor rebuilt about 2 yrs/ 24k miles ago. Now its seems to be having problems with the cold start. It will miss and jump up and down around 800-1200 rpms. Its sounds really bad, but it gets better as the motor warms up and always goes away after the first few minutes. It doesnt do this if the motor has been ran recently and is still warm.
Any ideas?
Old Mar 17, 2006 | 03:10 PM
84sr5yoty's Avatar
What motor, year??
Old Mar 17, 2006 | 03:19 PM
ChickenLover's Avatar
Originally Posted by NB4runner
Any ideas?
It sounds like a mixture issue to me. Your cold start injector might be malfunctioning. Your O2 sensor could be sending bad info, throwing the air/fuel ratio off.
I had a pre-warmup stutter that was solved with a new O2 sensor.
Old Mar 17, 2006 | 10:09 PM
8422r4Runner's Avatar
How old are the spark plugs? what does the inside of the dist-cap look like?
When the motor is cold, the gas is not preheated ( so to speak ) as it enters the cylinder, so it takes a good strong spark to make it burn. As the motor heats up, the gas gets heated by the motor, so it takes less spark to burn it.
Bad plug wires can also cause bad spark.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
