Cold Compression Test?
Old 03-21-2013, 09:43 PM
easterly81's Avatar
Only only ask because my motor is torn down to the valve cover. I wish i did one when the motor was running. so my question is, is a compression test done with the motor cold a viable way to test the cylinder compression relative to each other or a complete waste of time?
here is what i got
2-132 1-145
4-140 2-135
6-135 6-135
and is it also safe to say these figures and low but with a worm engine would most likely be over the 142 mark.
Sorry for the asking a question that is borderline retarded.
Old 03-22-2013, 01:57 AM
Co_94_PU's Avatar
Is that dry or wet? Did you do multiple tests and average them? Is this a rental gauge, they're known not to be really acurate and out of calibration alot of the time?
They're within the balance spec of 14#, max difference is 13 on yours.
This is of course just one guys oppinion. "Meh they could be alot worse, I'd say it's not bad for cold"
Old 03-22-2013, 08:40 AM
TNRabbit's Avatar
Spec is to do it with warm engine, VAFM & IGNITOR unplugged, ALL spark plugs out, wide open throttle. Turn over no more than 6 times. It really requires 2 people to do correctly. Warm engine would make a little difference, nut the main thing you're looking for is CONSISTENCY across all cylinders.
Old 03-22-2013, 08:52 AM
easterly81's Avatar
Yes rental, looked fairly new, or in good shape. I did do the test a few times seemed pretty consistent. Just trying to get a better picture before i dump a lot more money in replacing stuff. I wish i did it prior to tear down, started digging in and my shopping list of parts kept growing, pretty normal with this truck.
Old 03-22-2013, 12:06 PM
TNRabbit's Avatar
Have you pulled ECU codes? Why did you initially tear the engine down?
Old 03-22-2013, 07:30 PM
easterly81's Avatar
Pulled it apart cause the water pump started leaking and the cam plugs are leaking. Got the timing cover off and the valve covers off. I had to spend but $150 in hoses alone. I'm sure this is said a lot but, slowly but surly changing every part on my truck'but I still love it!
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
84'22r
02-13-2019 05:35 AM
the1998sr5
27
11-17-2015 09:30 AM
Sidherish
08-02-2015 01:42 PM
Quick Reply: Cold Compression Test?
