codes 25,31,32,24
Old 04-29-2009, 06:33 PM
iselloil's Avatar
codes 25,31,32,24
CEL came on,went off and came back on. 1993 4runner 3.0. Truck runs fine,but cant seem to find the problem,any suggestions?
Old 04-29-2009, 06:53 PM
89silverpu's Avatar
25 could be
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
31 could be
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
--AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
32 could be
--AIRFLOW METER SIGNAL (VANE-TYPE)
--AIRFLOW METER./CIRCUIT
--ECU
24 could be
--INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--ECU
I'd start with replacing the 02 sensors then go from there. That's the most common problem it seems.
Old 04-30-2009, 03:35 AM
iselloil's Avatar
Changed the plugs,NGK's and Ngk wires,Toyota Cap and rotor,Air Hog air filter.Put on new muffler and tail pipe, Ran great.Then codes showed up.The check engine light went off, and then came back on.
Old 04-30-2009, 04:15 AM
toyota4x4907's Avatar
Try clearing the ECU and see if they come back on.
Old 04-30-2009, 04:34 AM
iselloil's Avatar
on the 93 4runner, pull the EFI fuse?
Old 04-30-2009, 04:35 AM
BoostinChick's Avatar
You can just unplug the terminal from the battery for about 15-30 seconds.
Old 04-30-2009, 04:45 AM
Indeed. EFI fuse or + battery connection.
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: codes 25,31,32,24
