Code 42 but I have a mechanical cable?
Old 10-10-2009, 02:57 PM
securekey's Avatar
OK... I got some help in another thread diagnosing my check engine light. Turns out it is CODE 42... Speed Sensor.
However, I have a mechanical cable... it is not electric so I don't believe I have a speed sensor. The cable is turned at the transfer case and spins the speedo gauge in the cluster... nothing electrical or sensor related that I can figure out.
Anyway, I have a cable for sure (was just looking at it), speedo does NOT work, I have trouble code 42 ... plz someone explain.. my eyes are burning from searching lol
Old 10-10-2009, 03:36 PM
JeEVeS's Avatar
there is also a VSS for abs. We had a little run around a few times at the dealer getting the wrong part off a VIN. i am not sure on this but a 91 might be new enough to be equipped?
I recently received the same code except mine is from a 4phase 3wire - marlin adapter - rf1a cable case issue i think. on a 94 sr5 runner.
Old 10-10-2009, 03:55 PM
securekey's Avatar
No abs... but good thinking... anyone else?
Old 10-10-2009, 04:31 PM
RobD's Avatar
You sure you don't have rear ABS on your pickup? I know my 4Runner has, for sure and should have become standard on pickups in 1989, far as I can find out.
It might only work in 2WD.
Old 10-10-2009, 04:35 PM
Marc's Avatar
The speed sensor might apply to tranny shifting or cruise control.
The FSM should indicate what the code is for.
Old 10-10-2009, 04:36 PM
turboboost's Avatar
You sure you don't have rear ABS?
Old 10-10-2009, 05:03 PM
RobD's Avatar
Lookit Winnipeg representing!
Old 10-10-2009, 05:13 PM
securekey's Avatar
No abs, no cruise... 42 code and speedo/odometer not working... mechanical cable for sure. Any other thoughts?
Old 10-10-2009, 05:37 PM
securekey's Avatar
Halifax here
Old 10-10-2009, 06:10 PM
Dipstik_90's Avatar
Is the cable broken?
Old 10-10-2009, 06:16 PM
BoostinChick's Avatar
Did the cable break/pop off from the back of the cluster? When I had a code 42, it was my gauge cluster. I believe the code/error is No.1 sensor (which would be the tiny motor in the gauge cluster).
Old 10-10-2009, 07:42 PM
sb5walker's Avatar
In the cable speedos, the VSS is a mechanical reed switch inside the speedometer. If your speedometer isn't working, the vss isn't either. Prob a bad cable, possibly a broken speedo. The VSS can trigger a governor feature that cuts fuel when the toyota engineers think you're driving too fast; not sure what else it does.
http://www.motor.com/article.asp?article_ID=271
http://www.the12volt.com/installbay/...TID~98493~PN~1
Old 10-11-2009, 03:10 AM
securekey's Avatar
Nice. That is the information i was looking for. Makes sense after reading the article. Thank you
Blamalam
03-12-2022 07:34 AM
okamikai
04-30-2018 10:19 PM
raptor510
02-17-2017 07:11 AM
nonstop
07-24-2015 06:29 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Code 42 but I have a mechanical cable?
