CO Relay Question
Old 08-20-2011, 09:12 PM
the47guy's Avatar
CO Relay Question
87 4Runner 22RE. I know that the CO Relay has a lot of threads covering it, but still a little lost. If I have a click coming from the CO Relay, does that mean that my Main Relay is good or could it still be bad? I am getting only .4 volts to my fuel pump and have been trying to cancel out items. When I turn the ignition over, I get a loud click from the CO Relay. 4crawler's sight is amazing but overwhelming at the same time for this guy. Thanks
Old 08-21-2011, 12:59 AM
myyota's Avatar
Yes, even though you hear a click the relay can still be bad. Sometimes they can corrode on the inside and go bad.
Old 08-21-2011, 01:09 AM
wyoming9's Avatar
Smile
Just because the coil is pulling in.
You have no idea if the contacts are making good contact over the years they do get burnt they do wear to the point of not making good contact
Old 08-21-2011, 08:43 PM
the47guy's Avatar
Ok. Thanks. Can I clean those contacts or is it time to just replace the relay?
Old 08-21-2011, 10:19 PM
wyoming9's Avatar
Smile
I say if you were miles from a paved road you could try and clean them.
After testing the relay( It will show you how in any of the manuals) if it is not working I would get a new one
If the relay is working then the problem is else where.
look at the socket it plugs into for corrosion
okamikai
04-30-2018 10:19 PM
mussy01
12-13-2016 08:20 PM
stock87yota
07-31-2015 10:08 AM
jackiebrownia
07-20-2015 09:02 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: CO Relay Question
