Clutch question
Old 04-03-2009, 07:28 AM
Bobthebuilder's Avatar
Clutch question
My brother and I are swapping 3.0's in my 94 t4r. I'm putting in a new clutch @ the same time. Any recommendations? The truck will see some offroading but nothing super serious. Currently have 189k on factory clutch w/ some offroading in the last 50k w/ no issues. Thanks
Old 04-03-2009, 07:57 AM
Junkers88's Avatar
A lot of folks have gone with the Marlin Crawler Heavy Duty and like it.
Old 04-03-2009, 08:19 AM
Tubbyfatty's Avatar
Heres a great clutch, alot of people of recommened it. I am going to get it when i replace mine.
http://www.marlincrawler.com/clutch/...ch-kit-1200-lb
It feels stock but when it grips, it grips and never slips.
Old 04-03-2009, 01:13 PM
Thankya gents
Old 04-03-2009, 01:27 PM
Flash319's Avatar
OEM all the way.
Old 04-03-2009, 01:53 PM
Junkers88's Avatar
Just an FYI. If you only plan on ding limited wheeling you might consider going OEM. I'm replacing the clutch in my 89 next week with an OEM replacement from NAPA. It'll cost me about 120$ out the door for all the little parts. I wanted to go MC pretty badly but am on a budget and I don't do any serious wheeling and figure if the factory one made it over 200,000 miles then an OEM replacement will last at least half that with some weekend wheeling.
Just a thought.
Old 04-04-2009, 03:10 AM
TNRabbit's Avatar
Just be sure you at least refinish the pressure plate, or replace it.
Old 04-04-2009, 12:15 PM
Jay351's Avatar
Originally Posted by Flash319
OEM all the way.
Stick with oem parts. Get the marlin crawler HD clutch kit! ITs an oem clutch with more clamping force.. I have convinced quite a few guys on here to buy one..
x2 get it resurfaced with the proper step.
Old 04-04-2009, 12:22 PM
Tubbyfatty's Avatar
do you mean flywheel?
Old 04-04-2009, 03:13 PM
Catlin's Avatar
I replaced mine with a Centerforce clutch kit, and it has been fine for 40,000 miles. You should have the flywheel refinished and use those special hi-strengh bolts to reinstall it. Someone on another thread a few days ago put his back on with hardware store bolts and said they all broke off in operation.
I should have used a Toyota throw out bearing. I bought an off brand that looked good. It maks a tiny bit of noise sometimes. Replacing the clutch in a 4wd 4runner is a tough job, and you don't want to have to go back in there.
Old 04-04-2009, 05:08 PM
Tubbyfatty's Avatar
I believe that someone would be 91toyota....
Old 04-05-2009, 10:56 AM
TNRabbit's Avatar
Duh...that's exactly what I meant; brainfahrt!
the1998sr5
15
07-14-2020 08:35 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
upongame619
08-01-2015 12:12 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
1996Taco
07-20-2015 12:02 AM
Quick Reply: Clutch question
