clutch adj please help!!!!!!!
Old 01-16-2008, 09:31 PM
just a 22re's Avatar
ok i did search and yes i found some things to bad there no help old pdf files and no good links on the crack pictures so here it goes just like josh on here i replaced my master and my slave at the same time now the pedal is all the way at the top if i sneeze the clutch will slip i don't get it is there anyway i can get this so that its about 2 inches from the top or so just so that i know its not sliping when i had the STOCK parts from the show room the pedal was very very nice then it just disappeared on me and now i got this i cant shift hard or give it alot of gas or she will slip help!!!! and no its not cracked at all i looked and everything oh and the bolt looking thing that comes from the master is as far in as it can go before it hits the pedal itself i dont get it do i grind it down and go in more or turn it so it goes out to make it go down??????
Old 01-16-2008, 09:40 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
My pedal was way too high when I installed my new MC recently. I adjusted the pedal height and now it's perfect.
Run this procedure down and measure everything.
http://personal.utulsa.edu/~nathan-b.../2checkand.pdf
It's kind of a chore, but this really covers everything you're dealing with.
No...you do not need to grind anything.
Old 01-16-2008, 09:43 PM
thook's Avatar
That bolt looking thing is the push rod. You use that to adjust the pedal freeplay....not the pedal height....which is what you're dealing with. Capice?
Old 01-16-2008, 09:49 PM
yeah thats right man thanks im going to take a look at that link and see what i gotta do thanks man thanks
Old 01-16-2008, 09:54 PM
thook's Avatar
You're welcome, you're welcome. Just follow the instructions. It's a recipe for happiness...
Old 01-16-2008, 09:55 PM
ok thook that really didnt help me at all my clutch release is at the top!!!! theres no free play to shift gears all i have to do is rest my foot on the clutch and thats it i need to get the pedal down more so i have to push the pedal down atlest an inch or two my clutch is at the top and it didnt say anything about that in the pdf just the top stop thanks
Old 01-16-2008, 09:58 PM
thook's Avatar
Oh...incidentally. The clutch release point will change with adjusting the pedal.
Old 01-16-2008, 10:00 PM
ok then what do i do im a little dumbfounded here do i rase the hight so that the pedal goes higher or what i just dont get it here i've been trying to finger this out for about 10 hours stright now and i just dont get it thanks
Old 01-16-2008, 10:04 PM
thook's Avatar
Can you take any pics?
Old 01-16-2008, 10:05 PM
yeah pm me your email and ill send you a video and pictures ok im going out right now do take them thanks man really im kinda brain dead from this whole deal and all
Old 01-16-2008, 10:06 PM
thook's Avatar
The push rod.....it's as far in as it can go? Does that mean towards the MC or the pedal?
thook's Avatar
Okay...will do right now.
Old 01-16-2008, 10:30 PM
ok its loading the pics and im going to use winrar to zip the video its just a lil big for yahoo so i hope it will send the video shows everything thanks man oh and my name is allan to
Old 01-16-2008, 11:04 PM
thook's Avatar
Hey Allan.......Matthew.
Yeah, I was beginning to wonder. I keep checkin' my email to make sure you weren't sent to my junk box. I'm better with trucks than I am with computers. Although, I can type rather tenaciously!
thook's Avatar
BTW, do you still have your old MC?
Anyway, I have the feeling you've got the push rod itself turned to far out. With the old MC you would be able to check the measurement against the new. I'd measure the one in mine for you, but it's sitting a mile and half away with the motor apart...hahahahaha....ehem.
Old 01-16-2008, 11:21 PM
thook's Avatar
Have you sent the EM yet? It's 2:30 am here, dude. Me eyes are getting very heavy.
Old 01-16-2008, 11:26 PM
yes its sent man i was woundering where you went cause im geting very tired to but heres the link fot the pics
http://viewmorepics.myspace.com/inde...0-e0d923867ec2
Old 01-17-2008, 07:55 AM
thook's Avatar
Okay......I can't see that there's anything visually wrong with it. I have to make a run for hay early on today, so I can stop at my vehicle and check the push rod length. Then we can compare how yours lines up. Until then, get the pedal measurements and post them up.
Old 01-17-2008, 04:44 PM
ok ill go out right now and have a smoke and mesure out the pedal and everything guys
Old 01-17-2008, 04:56 PM
ok the pedal is 6" from the indent on the carpet and theres NO freeplay (clutch disinauges right at top) and at about 4.5" is when it ingauges so there 4.5" of play(travel) from the floor to the ingaugesing point and only 1.5" of start to full grab
Quick Reply: clutch adj please help!!!!!!!
