| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Clicking Noise coming from intake.
__________________
94' 4Runner Rock Krawler/Mudder |
#2 (permalink) |
What motor? How fast is the clicking -- is it in time with the motor rpms?
__________________
Jason ****4 sale!!!!!!!! 92 4runner 33X12.50 Pro Comp extreme mts 3" body lift Dual Rancho steering stablizers |
#3 (permalink) |
What happened to your old intake?
Are you installing a stock replacement or aftermarket?
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#4 (permalink) |
It is the 3.0 V6 automatic Trans. I would say it is in time with the RPMs. Sorta sounds like it worsens as the motor heats up also.
__________________
#5 (permalink) |
The old intake had the airbox drilled from the bottom by some retard. Why would you drill holes in the bottom of all places? Seems like if you ran through a puddle water would get to your filter. I put on a aftermarket intake because I could'nt find a stock replacement for it. I have just started on this truck and don't know anything about it's history. But, I do know someone cut a lot of corners with this rig.
__________________
#6 (permalink) |
Bump,
Anyone got any ideas on this?
__________________
#7 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Fuel injectors clicking?
__________________
Quote:
Insomnia: it's a way of life.
#8 (permalink) |
Can the fuel injectors really be that loud? I started noticing the same thing after I took off, cleaned, and reinstalled my intake... never noticed it before, but now it's audible and almost sounds like a tapping valve, lol... maybe that's all it is... or could be the 284K miles on the truck...
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace |
#9 (permalink) |
Exhaust leak?
__________________
4.3/5.0 Do iT!
#10 (permalink) |
from the intake?
maybe EGR valve leak possibly...
__________________
#11 (permalink) | ||
Quote:
I'm not saying that the injectors are the source of your noise, but they are one of those innocuous parts that make noise when they are working properly. You could make a poor-man's-stethoscope and check the noise: get a long screwdriver, ratchet extension or solid steel bar and place one end on an injector and the other end on your ear and see if the noise you hear through the 'stethoscope' matches the same interval as the clicking. You can use that same trick to locate the source of almost any 'hard' noise in the engine- just watch out for moving parts.
__________________
#12 (permalink) |
good tip, lol
most of the time when someone give that lil bit of advice, they speak from experience...
__________________
#13 (permalink) | ||
Quote:
I've used that 'stethoscope' trick to ferret out worn rocker arm bushings on an engine... and having that little bar pounding your head because you were dumb enough to put it on the end of the rocker arm as opposed to the rocker shaft teaches you a lesson pretty quick: a mistake I made only once. LOL
__________________
#14 (permalink) |
ouch!!!!!!
__________________
94 4runner 3vze a/t sr5 |
#15 (permalink) |
Broomhandle cut to the desired length.
#16 (permalink) | |
Moving parts does not always mean belts and fan blades.
![]() As for broom handles- they work ok for lower pitched 'knocking' sounds like rod bearings and the like, but don't conduct higher pitched sounds or 'clicks' from loose valves and injectors as well as steel.
__________________
#17 (permalink) |
I have a ticking noise and asked my local mechanic about it. He said it was the injectors.
Also the holes below the airbox allow for the engine to breathe better (made for people who don't go driving in water too much) Someone did a write-up that you might wanna see too. http://www.yotatech.com/f130/airbox-...-engine-75127/
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled. |
#18 (permalink) | ||
Quote:
There are fairly complicated calculations relating to air flow volume versus velocity that come into play. <- one of the reasons that swapping the AFM and filter with the battery is effective on 22RE's and why 'velocity stacks' work well on older carb'ed engines.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Clicking noise while in 4wd | MUDN4R | 86-95 Trucks & 4Runners | 7 | 06-15-2006 08:01 PM |
| Tracked down my clicking noise | swerks | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 03-02-2005 05:21 PM |
| Clicking noise--HELP! | GaBowman | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-27-2004 06:20 AM |
| Clicking noise?? | AznSky | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-30-2003 08:43 AM |
| HELP!! 3.0 V6 clicking noise | grandfeltcher | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-19-2003 10:47 PM |
