Cleaning up my Emissions
Old 12-03-2009, 03:27 PM
camo31_10.50's Avatar
i didnt remove any lines that had anything to do with the trucks well being LOL
i jumped the idle cut solenoid today..and the truck runs fine..so it's all down to the plug now....
i got power..continuity..and the solenoid works...but it won't work through the plug...only if i apply power to it with a different 2 wires..
i got continuity throughout the male side of the plug..and the female side..and i have power on the female side just like i should...idk whats up with it lol
Old 12-04-2009, 10:11 AM
yotaman90's Avatar
Check your distributor vacuum advance. Supposedly the engine won't idle if the diaphragm nearest the engine no longer holds a vacuum. But, I know for a fact that If I disconnect it on my 22R it doesn't affect it whatsoever. But thats how mine is, I dunno about yours
Old 12-04-2009, 03:25 PM
well i can't feel a vacuum on that particular diaphragm at idle..i'll check it though ..lol
if i hook up the idle cut solenoid STRAIGHT to the battery..then the truck will run fine.......im thinking there is a wiring problem somewhere..even though i have power on the female side and continuity on the male side...!?!?!??!? wtf LOL...according to the readings i got on my tester..it should work fine..but it doesnt.
Old 01-09-2010, 04:18 AM
cgeorge's Avatar
hey - whatever happened with this? Did you make EGR block off plates? If so, what material did you use?
Old 01-09-2010, 09:17 AM
  #25
didn't make any plates LOL, all i did was block off all my crap i didnt need,
truck runs great, except for the vacuum leak that i STILL have..my guess is the intake manifold..whenever it gets warmer i'm gonna start replacing gaskets lol
Old 01-09-2010, 10:44 AM
  #26
yoterr's Avatar
my truck runs fine without the emissions stuff...it wasnt working so took it off, the only prob i have is cold cold weather it runs like crap for about 10 min till it warms up, but i think its due to the AAP not being hooked up, but other than that i just have the CB vac advance brake booster and PCV hooked up,
Old 01-09-2010, 10:46 AM
  #27
yoterr's Avatar
i bought the kit from LCE but if i did it again ide just build some, cost me like 40 bucks fer that crap, if you dont care if your emissions stuff is still there you can make blockoff plates out of a soda can
Old 01-09-2010, 11:25 AM
  #28
1990yota-pickup's Avatar
are you sure your conectors are making a good contact..
Old 01-10-2010, 06:13 AM
  #29
texasc1985's Avatar
I took off all of that emissions, made block off plates, did some fill in welding and stuck a Weber 34 dgec. That truck has never run better, Asian carbs do not hold a light to a Weber. Power, better fuel economy, a smoother idle, starts up and runs when it is cold. The hardest part is keeping your foot off of the gas.
The OEM carb is designed to run with all those vacuum lines and sensors. Trying to run it without them is a difficult task, because you have to adjust the carb regularly. I never could get it to run properly, a carburettor specialist said it will never run right and it never ran worth a bowl of beans without ALL the emission's hooked up. Save the money and get a Weber.
Old 01-10-2010, 07:34 AM
  #30
http://www.webercarbsdirect.com/product_p/wk746.htm
i think you can find what your looking for at this site.
Old 01-10-2010, 06:23 PM
  #31
yea if i was to be keeing the truck for a while then i probably would go with a weber..but i got the '92 4runner to rebuild then i'm selling the '86 lol let the vacuum leak be someone elses problem for a while lol
Old 01-11-2010, 03:42 PM
  #32
what are u waiting on throw a webber under the hood
Blamalam
03-12-2022 07:34 AM
montanatruck
02-26-2017 07:07 AM
Corvoid
09-04-2015 11:55 AM
tj884Rdlx
08-28-2015 12:04 PM
utahman
08-23-2015 02:04 PM
Quick Reply: Cleaning up my Emissions
