Checking for Vacuum leaks/carb clearner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-11-2006, 05:54 PM   #1 (permalink)
rdharper's Avatar
I have a very mild rpm hunt, or oscillation... barely noticable, but always there after warmup. 4Runner runs fine otherwise.
The preferred method seems to be the use of carb cleaner that doesn't affect sensors. So I have a couple of questions.
1. I picked up a can of Gumout Carb + Choke cleaner. Its say it won't harm O2 sensors, but be careful of plastic and wiring. Is that the ok stuff?
2. Some people are concerned with the flammability. But I've not heard any reports of fire. Common sense use may be all that is necessary, but at my age I seem to worry alot. How "safe" is the carb cleaner on a warm engine?
3. I understand what we are looking for is an increase and steadying effect on the rpm's. Is that because we temporarily seal the leak, or because some gets sucked in (I suppose depending on which vaccum hose) and makes it way to the air intake? Just what is the theory?
Thanks
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 158K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg
'08 Honda Ridgeline RT 2.6K miles 16mpg
'06 Honda Rincon ATV 410miles/65hrs 22 mpg
rdharper is offline
Old 11-11-2006, 07:09 PM   #2 (permalink)
yota_krazy's Avatar
Your theorys sound ok to me. Just dont spray around or at the distributor/wires and you will be fine.
yota_krazy is offline
Old 11-11-2006, 07:50 PM   #3 (permalink)
89dlx's Avatar
I'd say use throttle body cleaner instead. Be sure to use the "small hose" that comes with the can so that you can pinpoint the leak.
89dlx is offline
Old 11-11-2006, 08:21 PM   #4 (permalink)
fthertime666's Avatar
how bout a propane torch? The carb cleaner Ive used shoots out at about a
million psi.
__________________
US ARMY 63B, 94 toy PU, bj spacers, Downey adjustable front shock mounts, lo-pro bumps, 2in lift in the rear, 2inch BL with poly mounts, POS 22re, 4.88s with rear ARB, 33x10.5 BFG MTs, Bigrocks front and rear bumpers, Siege Engineering OBA
fthertime666 is offline
Old 11-11-2006, 09:03 PM   #5 (permalink)
Send a message via AIM to dcg9381
I've never had luck with propane.. It's too hard to get in the cracks. with carb cleaner, my point and shoot is much more accurate.
__________________
http://www.22REturbo.net
dcg9381 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Coolant leaks and oil leaks on a 91 4runner L33mur 86-95 Trucks & 4Runners 5 05-21-2007 01:37 PM
Checking TPS.. where does the vacuum for the throttler go? n8inks 86-95 Trucks & 4Runners 10 09-12-2006 04:51 AM
too lean CEL, what's a good way to check for exhaust leaks and vacuum? firedog 95.5-2004 Tacomas & 96-2002 4Runners 0 12-11-2004 07:45 PM
checking for exhaust leaks evilcow 95.5-2004 Tacomas & 96-2002 4Runners 3 10-03-2004 06:24 PM
97 4Runner rear axle leaks - HELP an Aussie !! R cannot stop leaks !!! beddo 95.5-2004 Tacomas & 96-2002 4Runners 8 08-06-2004 05:48 PM
2009 InternetBrands, Inc.
