check engine light! doh!
Old Jan 21, 2008 | 03:49 PM
RedRider's Avatar
Angry check engine light! doh!
This is confusing. My 87 4runner (manual 4x4) is acting perfect. After 5 to 10 minutes of driving down the highway, the check engine light comes on. I only have to put it into neutral for a split second, slip it back into 5th, and the light goes off 4-10 seconds later...only to come on a couple minutes later. I already changed the fluids on everything (front and rear differentials, transfer case, and transmission). Any ideas?
Old Jan 21, 2008 | 03:54 PM
Erich_870's Avatar
I can't remember from my old 87 4runner, but how is your break fluid level?
Erich
Old Jan 21, 2008 | 04:07 PM
jason191918's Avatar
Just because the light goes out does not mean the problem is gone. Sometimes the light goes out, but an error code is still stored. Autozone will pull the codes for free, or you can use a manual to do it yourself. What kind of a truck do you have? Maybe I could help. You should put your info in your signature.
Welcome to YT! You came to the right place.
Old Jan 21, 2008 | 04:14 PM
EWAYota's Avatar
Get the codes pulled. You can actually do that yourself with a paperclip. You just need to jump two terminals (E1 & T1) I think.....check www.4crawler.com under cheap tricks, as he shows you how to do it.
I would say check autozone, but last time I had my CEL come on, they couldn't pull OBD I codes, only OBD II. Paper clip works just fine.
Old Jan 21, 2008 | 04:16 PM
EWAYota's Avatar
Erich
Had to catch myself on that one. If the brake fluid is low, his emergency brake light would be stuck on or turn off and on.
Old Jan 21, 2008 | 06:40 PM
toytech76's Avatar
betcha its an o2 sensor code
Old Jan 21, 2008 | 07:01 PM
ScottyC's Avatar
Yup, use the paperclip deal in the diagnostic port on the passenger inner fender. Use E1 and T1 and then count the codes thrown. My guess is that its throwing a 25 and 26. Usually for a rich/lean condition normally from a bad O2 sensor.
Old Jan 21, 2008 | 07:21 PM
RedRider's Avatar
I really appreciate the advice; unfortunately i can't look at it until after next weekend. However, i had a quick question of why slipping in and out of 5th effects the CEL?
Old Jan 21, 2008 | 07:44 PM
rowdy235's Avatar
Do you let off the gas in Neutral? Could be not the slipping out of 5th but the decrease in RPM
Just a thought
Old Jan 30, 2008 | 12:17 PM
RedRider's Avatar
Thanks for all the help everybody....so helpful
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
