check engine light
Old 02-22-2009, 08:55 AM
wbthornton88's Avatar
check engine light
The truck is a 95 3.0 4x4. The check engine light has been on for a while now. I'm trying to make this quick so I'm just going to give some symptoms. I have yet to check code from research sounds like a 25/26 or something. Crank truck after it hasn't been ran for over 12 hours and it wants to warm up acts like its not gettin gas when you try to go. After a good 30 seconds the truck idles up to 1500 rpm and gets gas fine. After warmed up truck idles back down to 1000. When I get on the rode as I get into usually second gear and around 2000 rpm the check engine light comes on and I can immediately feel a loss of power. Almost as if the truck just bogs down. Any ideas?
Old 02-22-2009, 08:57 AM
iamsuperbleeder's Avatar
oh boy... could be O2 sencor, TPS, ignition, fuel injector(s), and on and on and on...
need to pull them codes to at least get a place to start, it's not that hard...
Old 02-22-2009, 11:06 AM
ok can you tell me how to do that? I remember reading something.
Old 02-22-2009, 11:10 AM
rock slayer's Avatar
under the hood on the right side there is a diag box you need to jump a wire acrost 2 of those terminals the same ones to do timing it should tell you which those are on the underside of your hood then turn your egnition to on and count how many times your eng light flashes
Old 02-22-2009, 11:11 AM
abecedarian's Avatar
under the hood, find the diagnostic plug behind the battery.
insert jumper between the TE1 and E1 terminals- there should be a diagram on the underside of the lid.
turn key on (don't start) and count the flashes.
Old 02-22-2009, 11:12 AM
so flash flash.......flash flash flash.........long pause..........repeat would be 25
or flash flash.......flash flash flash.................flash flash.......flash flash..........long pause..........repeat would mean 25 and 22
Old 02-22-2009, 11:17 AM
what type of wire?
Old 02-22-2009, 11:21 AM
ok I found the lil gray box. Theres gunk all in the terminals. I guess Ill try to scrape it out.
any lil wire 3 in long or so doesn't really matter long as it fits in the terminal
Old 02-22-2009, 11:22 AM
dont scrape it out thats dielectric grease
its supposed to be there
Old 02-22-2009, 12:21 PM
ok the code is flash flash, flash flash flash flash flash, flash flash flash flash flash, flash flash, and then it starts over so 1 2, 1 2 3 4 5, 1 2 3 4 5, 1 2
Old 02-22-2009, 12:24 PM
so its 25 and 52
Old 02-22-2009, 12:26 PM
hold on i will check my book
Old 02-22-2009, 12:27 PM
25 is air fuel mixture lean and 52 is knock sensor its a 3vz-e right
Old 02-22-2009, 12:31 PM
thats what I just thought. What is the knock sensor?
Old 02-22-2009, 12:34 PM
the knock sensor is the worst thing to replace lol :/ it senses a spark knock condition in your engine and lets your ecu know to advance the timing to compensate if your standing in front of your truck the wires come out fron under the right fuel rail between injectors for cylenders 4 and 6
Old 02-22-2009, 12:37 PM
yea 3vze Its telling me the knock sensor is detecting a knock right? How do I know whats causing it though
Old 02-22-2009, 12:38 PM
so basically its telling me my timing is slightly off?
Old 02-22-2009, 12:41 PM
no its telling you there is a malfunction the ecu should compensate for it and you would never know
thebook says it could be 3 things and i doubt it would be the third
1open or short in knock sensor circuit
2knock sensor(loosness ect.)
or 3 ecm
Quick Reply: check engine light
