Check engine light
Old Jan 20, 2007 | 08:17 AM
poolman's Avatar
Check engine light
92 pick up 3.0 1 ton automatic 145k+
Ran diagnostic (code 25)
checked out symtons listed on off-road.com/toyota
checked all wiring
checked vac lines
replaced fuel filter
replaced plugs and wires
cap and rotor
new O2 sensor.
runs great! idles rough though in gear only?
check engine light comes on after a good long drive? (temp here in the 50's)
ran injector cleaner/fuel additive
today: check MAP sensor connection and vac lines
Any input? thanks for any help, poolman
Old Jan 21, 2007 | 08:31 AM
tc's Avatar
tc
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Code 25 is "Air-Fuel Lean Malfunction"
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Might try some Seafoam through a vacuum line to clean out the throttle body and intake.
Old Jan 22, 2007 | 07:30 PM
poolman's Avatar
Runs good again but bleeping CEL comes on after about an hours worth of driving. No smog checks here in the valley. Any more places to look? thanks, pm
Old Jan 22, 2007 | 07:31 PM
poolman's Avatar
OK newby question WTF is sea foam?
Old Jan 22, 2007 | 08:06 PM
poolman's Avatar
found it....
Old Jan 22, 2007 | 08:48 PM
fork's Avatar
tailgater repellent
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
