Chaos Fab users
Chaos Fab users
Quick question, I drive a 1987 Toy truck with 22ret. I installed the Chaos Fab last summer, think its the Gen 1, but it has the torsion bars, not the coil over. For the last month I have seemed to notice that the front seems to be sittin a little lower than normal. Today I adjusted the torsion bars up aprox 1 1/2 inches on inch side. Yeah it seems to sit level, but the Chaos A arms are aprox 1/4 in from sitting on the bump stops. I dont like the idea that I will now have no downward travel but that 1/4 inch. When my truck is sitting on a flat surface the measurement from the ground to the frame just behind the lower Chaos control arm is 21 1/2 inches, prior to adjusting the torsion bars the height from the same area was 20 inches. I think. So, if anybody who has a Chaos Fab LTS,could you please give me a measurement from the frame to the ground from behind the lower control arm. I would appreciate that.
I am running 33" BFG's as well and they are at 35 PSI.
JMach1
I am also looking at possibly selling all of the Chaos Fab components and going SAS at the end of this summer.
JMach1
On a t-bar setup there isnt a lot that would cause you to sag. As long as you can adjust the bars you will have the same height, and travel.
is it possible the rear is higher, did you remove something heavy?
I was getting worried that the Tbars were already wearing out, I have a 4 " lift in the rear and I really dont remember if it sat that level from front to rear when installed. What I will end up doing tomorrow is putting the height back to where it was.
Sounds good, I think I will put mine back to 19-20 inches. Do you have any close up pics of your lower bump stop when it is on level ground? And what brand fiberglass are you running. I have Glassworks front and rear on mine.
Thanks JMach1
Thanks JMach1
Okay, they both look pretty much the same. Makes me feel better. Since we are running the same Glassworks fenders can you now measure from the top of the rim to the fender and see if we match. Mine is at 19 3/4 inches both passenger and driver side. Because if we do I am not touching a thing. I think it rides good as well it lifts the front up a bit.
Yesterday when I cranked on the TBars my upper a arms were about a 1/8 of an inch off the droop stop shown in photo.
Today they are where you see them.
Thanks JMach1
19 3/4 inches
Thanks JMach1
19 3/4 inches
kawazx636
10-06-2021 03:03 PM
nvwiggins
13
06-16-2016 03:05 PM
FS[International]: 4runner rear bumper plastic pieces
crashburnoveride
05-28-2016 09:08 AM
live4soccer7
05-11-2016 06:52 PM
