is the celica or mr2 turbo manifold SAME as the 22re?
Old 08-16-2006, 10:55 PM
indica4r's Avatar
is 3s-gte turbo manifold SAME as the 22re or are there any other manifolds that line up with the 22re? donot want to buy LC's manifold. looking for a cheaper option. waht about the mr2 turbo mani?
Old 08-17-2006, 05:45 AM
trythis's Avatar
How about use the stock manifold? It isnt really a bad manifold. Just run some 2 inch pipe to the cat and 2 1/4 behind that. Ther is a thread on another board that talks about the manifolds, headers, written by Engine Builder that says that the stock manifold was equal to many of the headers available. This is a great read too.
http://www.4x4wire.com/forums/showfl...&o=365&fpart=1
Old 08-17-2006, 06:36 AM
CGOULET's Avatar
if your talking about the exhaust manifold, there are aftermarket options other than LC.
i got a thorley header ceramic coated for 260. and uncoated was only 200. i got them from autoanything.com i havent had a single problem with it, no leaks and very high quality, the single header weighs more then both of the full length headers on my camaro.
edit: they also have free shipping
http://www.autoanything.com/exhausts...A2787A0A0.aspx
Old 08-17-2006, 06:38 AM
Staff
DeathCougar's Avatar
The 3sgte is not even close to the same manifold as the 22RTEC engine. If you are building a Turbo engine, you may as well do it right the first time!
Old 08-17-2006, 12:10 PM
DN1911's Avatar
also GotPropane.com sells new Toyota turbo exhaust manifolds. much cheaper and easier than aftermarket.
Old 08-28-2006, 12:40 PM
dcg9381's Avatar
The catch with the turbo manifolds is to use a flex pipe in the down pipe - prevent cracking of the turbo/manifold.
mskalmus
05-28-2017 07:51 AM
RatOmeter
10-22-2015 03:17 PM
toofly1999
07-25-2015 07:09 PM
karbin
07-05-2015 11:37 PM
Quick Reply: is the celica or mr2 turbo manifold SAME as the 22re?
