CB picking up engine noise? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-23-2007, 11:12 PM   #1 (permalink)
Kiff's Avatar
So I just installed a CB in my 4runner, the antenna is at the back, but when the squelch is turned down, the cb puts out engine noise, the frequency fluctuates with the engine RPM. what have I done wrong? is this normal?
__________________
91 4runner - 3.0 - 5spd | 6" lift | 35" X-Terrain | Roof basket | Hella AUX lights | IFS brace | 2.25" x-over eliminator and Magnaflow exhaust | ISR | 5.29's | F & R Detroits | Cobra CB |
84 VW Diesel Rabbit....47mpg
Quote:
Could you explain to me what a rabbit is??? and how you did this? sounds pretty damn good to me..and whats the deal with the insurance on it?
Kiff is offline
Old 07-24-2007, 09:04 AM   #2 (permalink)
Red3.slow's Avatar
Send a message via AIM to Red3.slow
bad ground
__________________
-Miles
-Firefighter/EMT
T.E.A
Taxed Enough Already
Red3.slow is offline
Old 07-24-2007, 03:17 PM   #3 (permalink)
95ToyotaPU007's Avatar
I'm going to say bad ground too. Make sure you scrape away some paint where the ground cable contacts the chassis.
__________________
'95 PU Ext. cab, 4wd OEM 3.0L with spark delivered by OEM Ignition
348,xxx miles, on sixth set of tires sittin' on OEM wheels
'04 Silver Corolla S, DVD head unit going in soon
'85 F-250 351W H.O. 401,000 miles, first 351W dead at 367,xxx miles, Hedman headers, flowmaster exhaust, $1200 audio system, Alpine Alarm
95ToyotaPU007 is offline
Old 07-24-2007, 03:23 PM   #4 (permalink)
olharleyman's Avatar
Quote:
Also run directily to your battery posts and add a fusible link on the positive side
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 07-24-2007, 03:45 PM   #5 (permalink)
mt_goat's Avatar
I've had the same problem, I ran a twisted pair straight to the battery posts and it didn't help. Next I tried an inline noise filter and that got rid of about 75% of it but still have some.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 07-25-2007, 11:05 PM   #6 (permalink)
stormin94's Avatar
calibrate SWR. make sure it's less than 3. or check your grounds. and also check your antenna mounting. how far above the roof does it stick up???
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 07-26-2007, 01:34 AM   #7 (permalink)
drew303's Avatar
Every CB I've seen picks up some engine noise.
I got a cobra night something or other... sorry its way to late and im way to tired to remember ANY specifics atm...
anyway, mine picks up noise from the air fan more than anything but theres some switch on the CB (on mine .. cobra nightwatch thats it)... that eliminates engine noise pickup...
SWR meters are for tuning your antenna so the bandwith is tuned to the CB. Usually tune it so its equal above and below chan 19 but some truckers center it on their preferred or most used channels.
and like i said im to damn tired to remember what SWR metering range is optimal... I remember something like below 2 at chan 1 and 39 is good. .. Its mostly to save the CB from frying when you transmit a signal. You can hurt them if you try to transmit with an antenna thats totally not tuned (to long or to short).....
Firestik antennas have the adjustable screw at the top... HIGHLY RECCOMENDED over the "snip the wire" types.
__________________
1987 Pickup, single cab, 22R, new head, 260 cam
TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac.
drew303 is offline
Old 07-26-2007, 05:52 AM   #8 (permalink)
Send a message via AIM to dcg9381
Google search: "ground loop" - some noise is normal. You can go to an inline filter after you confirm that your ground is good.
__________________
http://www.22REturbo.net
dcg9381 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
engine noise in cb... really wierd deserttoy84 GPS & Communication 3 08-20-2007 12:29 AM
CB Engine Interference? drock2 General Electrical & Lighting Related Topics 1 07-17-2007 01:47 PM
Whining noise thru cb speaker Ironmike4x4 GPS & Communication 12 10-12-2006 12:05 AM
lotsa noise from my CB HawkFanatic GPS & Communication 5 07-24-2005 02:44 PM
Alot of engine noise in my CB while driving ! Stegall984R GPS & Communication 3 02-19-2005 04:22 PM
2009 InternetBrands, Inc.
