Cargo Rack Basket
Old 08-22-2007, 09:44 AM
keithguts's Avatar
Cargo Rack Basket
I'm thinking of getting a cargo rack for my rig. Not looking to put anything in it tho, as it is only for looks to the rig. I was thinking of getting the BLACK WIDOW
Have any of you ever heard of this brand, and what do you think? Cost is $99.00
TAKE A LOOK:
[IMG][/IMG]
Old 08-22-2007, 10:04 AM
keithguts's Avatar
any one...................
Old 08-22-2007, 10:08 AM
OSU4Runner's Avatar
I heard they were pretty crappy racks. You could spent another $50 and get a surco safari rack. Looks better and will hold up alot longer.
Old 08-22-2007, 10:27 AM
KGcliford's Avatar
what is the point in getting a roof rack unless you might use it? a 200 lb capacity is plenty for holding nothing
Old 08-22-2007, 10:31 AM
OSU4Runner's Avatar
Yea he has a point. If you're going to mount the thing up there, you should at least get some use out of it. It will decrease your MPG.....Do you want it just to mount lights on or just for looks?
Old 08-22-2007, 10:53 AM
keithguts's Avatar
Just for looks............. I might at some point put little stuff in it for my job, but donot plan on anything big at this point.
As far as decreaseing my MPG, how much can it use only being 18lps
Old 08-22-2007, 11:01 AM
hillbilly's Avatar
The roof rails are designed to hold only 165lbs...
Old 08-22-2007, 11:02 AM
Mattabilly's Avatar
If you buy a Thule or Yakima you get a lifetime warranty, plus Thules are made in the USA. Even though it says 200 lb. capacity your factory roof rack is only rated at 100-165 lbs. But if it's just for looks, what the heck.
Old 08-22-2007, 11:10 AM
excableguy's Avatar
I bought the same one, and structurely, it did great for what I used it for, and I liked all the different points you attach your cargo to. But there was one drawback--It comes in 2 pieces, which is easy for assembly, but mine took on a little water from rain and eventually leaked out a nasty rust-water stream. I ended up using black silicone sealant around the joints. It seemed to solve the problem, and you really couldn't tell it had been sealed.
Old 08-22-2007, 11:21 AM
keithguts's Avatar
So are you telling me that you got the Black Widow? If that is the only problem, (2 peices) I will seal it before putting it together. Also, did it do anything to your MPG?
Old 08-22-2007, 11:32 AM
ewong's Avatar
they HOWL in the wind w/o an air dam or super swamper tires
Old 08-22-2007, 01:21 PM
Mattabilly's Avatar
Most companies make these two piece to cut down shipping charges.
Old 08-22-2007, 02:31 PM
Henrythewound's Avatar
The MPG thing has to do with degrading the aerodynamics of your vehicle, not adding significant weight. See the "howling" comment above. I'll bet this factors in at higher speeds for the most part.
Old 08-22-2007, 03:08 PM
jay33's Avatar
I have one and had the same problem as excableguy with the water getting in it and spilling rusted water all over my roof, which only happened after the first hard rain and hasn't happen since. But other than that it has served me well. But the most gear I have put up there it snow skis and snow boards.
Old 08-22-2007, 03:09 PM
frodin1's Avatar
I was thinking about it, until I realized it won't fit in the garage anymore.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Obmi
10-04-2015 11:30 AM
Scotttekoch
09-28-2015 10:30 PM
Badfish740
09-04-2015 04:21 AM
dguzzi
09-03-2015 08:48 AM
Quick Reply: Cargo Rack Basket
