Can that silver thing leak oil?
Old 08-24-2008, 03:38 PM
project91's Avatar
I just finished my 3vz conversion from a 22re and fired it up...runs good, sounds good. So when I go to check for leaks, no coolant leaks, but when I look under the truck I see oil dripping about a drip per second. It seems to be coming from behind the round silver thing on the driver side of the block, the one that has coolant hoses going to it. Can this leak oil? And what is it called that way I know what parts to go buy to make it stop leaking?
Old 08-24-2008, 03:42 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Some pics of this silver thing would help us to see your problem.......
Old 08-24-2008, 04:18 PM
galloway's Avatar
ya pics will help alot
Old 08-24-2008, 05:27 PM
91yota3.0's Avatar
the round silver thing is probably the factory oil cooler
Old 08-24-2008, 05:34 PM
project91's Avatar
OK that would explain why it leaks oil, but has coolant running throuh it. To cool the oil that passes through from the oil galley. Its dark and rainy here so I can't get a pic up. But its about the size of a baseball, has a large bolt that runs through it and the water pump has a rubber tube that connects to it. On the top of it I can see another rubber line coming from it that probably returns the coolant to the block. What is it called?
Old 08-24-2008, 05:49 PM
Jeenyus04's Avatar
well someone suggested its your oil cooler so im gonna have to go with.. oil cooler
Old 08-24-2008, 06:41 PM
91yota3.0's Avatar
yup its the oil cooler mine went tits up on my motor, dealer wants almost 500 for a new one.
Old 08-24-2008, 08:16 PM
just a 22re's Avatar
or you can go to autozone get a cooler for anything and reroute the bad boy makes it easy and simple plus you can make go behind the front grill and get rid of the coolant lines going to it just a though and its way cheaper
Old 08-25-2008, 12:09 AM
GDR
GDR's Avatar
I just redid the O-rings on mine. If you have the 2wd version then you need 2 O-rings.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/119oilcoole.pdf
Old 08-25-2008, 03:33 AM
project91's Avatar
So the o-rings are in-stock at the parts store? They aren't a dealer item?
Old 08-25-2008, 09:58 PM
GDR
GDR's Avatar
You can try a parts store but I got mine at the dealer.
Old 08-25-2008, 10:00 PM
904_runner's Avatar
whats up project91, sorry can't help you don't know what it is, good seeing someone from ttw!
Old 08-26-2008, 04:56 AM
zlathim's Avatar
On the 4x4, I found 2 o-rings and also a steel/rubber washer for the center bolt. I would hit up the dealer, but you may be able to get them elswhere.
Old 08-26-2008, 07:37 AM
project91's Avatar
GDR--how much did the dealer charge you?
Old 08-26-2008, 09:56 AM
project91's Avatar
Called th elocal dealer and believe itor not they had them in stock!! 10 bucks plus tax, but what do you expect for a direct dealer item.?
Old 08-27-2008, 01:00 AM
drew303's Avatar
ill play devils advocate, but why on earth would you put a 3vze in place of a 22re?
Old 08-27-2008, 01:33 AM
GDR
GDR's Avatar
Because he wants to be slow not slowest.
Old 08-27-2008, 02:31 AM
jimbos_4runner's Avatar
hey guys, just had my head gasket replaced, and now i have a serious oil leak on the drivers side of the engine, it doesnt seem to be from the rocker cover, any clues what it could be, like whats between the sump and the rocker that could possibly leak oil, im taking it back to the mechanics tomorrow, to get them to fix it. Just wanted to know if any of u guys had any suggestion on what it could be. would help a bunch, oh its a 3vz-e engine by the way lol.
Old 08-27-2008, 03:05 AM
Noltz's Avatar
More than likely it is the rocker cover. The only other gasket on the block between the rocker and the oil pan (sump) is a head gasket.
Your mechanic will inspect it and let ya know.
Old 08-27-2008, 05:06 AM
zlathim's Avatar
The oil cooler is in that exact area between the valve cover and the oil pan on the driver's side of the engine. If it is leaking, it will be a pressure leak and probably pretty messy.
Quick Reply: Can that silver thing leak oil?
