Camber off badly after ball joint replacement.
So my yotas frame just hit 200k. First off, the truck has a lift on it. I got the truck with the lift already on it. It has after market upper a-arms, diff drop, and I think the lower ball joint mounting brackets are lower then stock.
So I replaced to upper ball joints (along with all the tie rods, lower ball joints, pitman are, and idler arm) today and now the camber is way off. Looking closer at the upper ball joints I removed, the ball joint socket is sitting angled (maybe like 5-6 degrees off perpendicular) compared to the mounting surface, where as the stock one is perpendicular to the mounting surface. I am sure this is what is causing the camber issue.
I did not notice this util I had it all back together. Dose any one know what they call these types of ball joints and where I would find them???
All ball joints should be the same. Even if what you're saying is true, that wouldn't change the camber. It's not about the angle the upper ball joints sit. They can adjust to whatever angle automatically, it makes no difference as far as camber.
What it is about is the angle that the lower ball joints sit. That's why you make camber adjustments with the LCAs.
If the upper ball joints were slightly thicker/thinner, just like adding/subtracting a small ball joint spacer, that might change the camber a little. Not much though.
Yes what Hippy is saying is correct... the ball joint does pivot.. hence the reason using them... The ball joint should be installed correctly Are they bolted down or pressed in properly... this if out, can effect the camber. Not huge, but I have seen on some press in models. verify everything is good and tight... If bolted, how is the ball joint mount seated... bolt holes have slop... and could have been all the way to one side on the old... and new bolted up to the outside of the control arm... do u get me???
OK, I understand what your both saying, but the ball joint that came off looks different then a stock toyota ball joint. Here is a pic to maybe help you guys understand what I am saying.
The shaft of the ball joint physically sits in a different location on the a-arm then the stock one. The ball joint is not mounted at the center of the ball joints mounting plate. The plate is wedge shaped. These upper ball joints are defiantly not stock Toyota parts. They look like they were powder coated red when they were new.
Lets say I measured from the frame to the ball joint on the upper a-arm. The stock one would be at least a 1/4 to 5/16th inch closer to the frame them the after market one. So its as if the a-arm is now 5/16th of an inch shorter, in turn pulling the the top of the knuckle, producing negitive camber.
Heres a pic of the after market ball joint:
Note that the ball joint shaft IS centered (although it make look like its not) in the ball joint socket in this pic. If it were stock, it would be sitting perpendicular to the mounting plate.
Im guessing you have torsion bar upper CA's??? yes / no If the ball joint's are different in shape as you say this will cause some differences as you say... thats a pretty big difference in factory vs aftermarket design..
Downey used to sell "mega travel ball joints." I couldn't find any pictures of them in google, but I wonder if that's what you pulled off your truck? If that's the case, unfortunately they are outta business...
I found a pic, doesn't show much.
TOYOTA DOWNEY OFFROAD A ARMS EXT, TRAVEL BALL JOINTS :
$225
DOWNEY OFF ROAD EXTENDED TRAVEL A ARMS WITH BUSHINGS AND EXTENDED TRAVEL BALL JOINTS FOR 84-95.5 TOYOTA 2 WHEELER PRE RUNNER SET UP. THEY HAVE NO MILES ON OR OFF ROAD ON THEM AS I NEVER FINISHED THIS PROJECT TRUCK.
http://www.collectorcarsforsale.com/...654104795.html
Just curious, why do you think they needed replaced? And...BTW a) your pics aren't showing up, b) have you tried adjusting the camber yet?, c) what brand are these?
The OEM ball joints don't sit flat like you're suggesting.
$225
I wonder if the ones I got were meant for 2WD? Look at the pic with my red control arm... the new ball joint is installed... is it meant for 2wd, can anyone tell just by seeing it on there?
The following users liked this post:
thescirocco (11-28-2021)
Hey guys, So I think I might have the same problem. I took my truck to Toyota for the steering relay rod recall and when I got the truck back they told me that the camber is as far as they can get it. They told me to go out and buy some off camber ball joints. Can anyone point me in the right way with this and if anyone knows where I can get some here in Cali for cheap but not to cheap you know don't need to be doing it all over again in 6 months.
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
