Cam Shaft positioning
Old 11-02-2006, 06:10 PM
benwahballs's Avatar
Ok going to put my heads back on my 89 pu 3L and I noticed I'm not sure which way the cams were in when I took them out. I do not meen end for end, I mean as far as rotational. There are 3 ways they can sit in the heads. It says nothing in the FSM about this, either for installation or removal. Wouldn't it make a HUGE difference? really scratching my head..
Old 11-03-2006, 12:14 AM
ChickenLover's Avatar
It doesn't make any difference.
Old 11-03-2006, 10:35 AM
thanks chicken lover. really appreciate it.
Old 11-03-2006, 04:36 PM
^VooDoo^'s Avatar
Yes it makes a difference!!!!
The cams have marks on the sproket and there are markes on the top of the backplate, line those up.
The mark for the crank is on the lower belt sproket and it lines up with a mark on the oilpump, This should all be TDC.
Cant belive thats not in the FSM when its in my crappy Haynes.
Old 11-03-2006, 04:41 PM
The cam sprocket can only be put on the cam one way. Initial installation of the cam into the head does not matter. He will line everything up later, when he's timing it.
Old 11-03-2006, 09:39 PM
95ToyotaPU007's Avatar
agree.
Scatpac
05-25-2017 06:47 AM
greasyglue
12-12-2015 12:57 PM
Dakotaneu
08-15-2015 07:24 AM
trailgoat
08-13-2015 05:54 PM
nonstop
7
08-11-2015 09:26 AM
Quick Reply: Cam Shaft positioning
