Cadillac Horn
Old 08-13-2009, 04:01 PM
93YotaGuy's Avatar
Cadillac Horn
So today I went to a junkyard to help a friend pull some parts and I happen to come across a 1976 Cadillac El Durado. The car was a boat and since I have been needing a horn I decided to pull it off. I payed a whole 4 bucks for it!
The horn sounds amazing! Such a big upgrade from the stock!
The only downfall to this is after installing it I played around for a bit testing it and when I went to show my brother it just stopped working. I checked the fuse in the engine bay marked HAZ/HORN and all of the fuses in the fuse box and they all seem fine. The wiring looks like it didn't fall out of place so I am stumped. Any ideas?
Old 08-13-2009, 04:04 PM
OutlawMike's Avatar
Check the ground, when I put mine in I had to make sure the ground circuit was correct. I put two of them in, one Tone E and one Tone F. Damn, they are loud.
Old 08-13-2009, 04:21 PM
93YotaGuy's Avatar
I just checked it and sure enough it was the ground!
Thank you for the insight!
Sometimes I miss the smallest easiest things... Now it's back to sounding amazing!
Old 08-13-2009, 04:28 PM
iamsuperbleeder's Avatar
haha, maybe it's because it's a 33 year old horn
I've been meaning to upgrade mine... it sounds so puney... it's imbarassing...
Old 08-13-2009, 04:32 PM
93YotaGuy's Avatar
Ha yeah well I haven't had one for years now cause the other one broke. When I get my camera back i'll post a video of what it sounds like.
The horn works great now. I threw in a couple of lock washers between each one and fixed the grounding issue.
before I just had them attached to the frame with a bolt and now it's fastened on their nice and tight!
I highly recommend getting this horn setup!
Although it may be 33 years old it still blows the stock horn out of the water!
Jealous much?
Old 08-13-2009, 08:02 PM
OutlawMike's Avatar
Did you put more than one in? Some Caddies had a four horn setup, that sounds like a train. Where did you mount them?
Old 08-13-2009, 08:04 PM
Jay351's Avatar
Sweet! I love my ford 2 horn setup. Best $10 I ever spent.
Old 08-13-2009, 08:10 PM
ShortyzKustomz's Avatar
I like my air horn, runs off 160 psi from my air tank, makes small children cry
Old 08-13-2009, 10:09 PM
sundog kid's Avatar
Coolest horn I ever swapped was from my old 83' Volvo 244 DL. If you ever have a chance to hear one, I would recommend it! lol
Old 08-14-2009, 04:17 AM
93YotaGuy's Avatar
The setup I put on only had two horns. The way it sounds it is more than plenty! I'll post a vid here tomorrow night so you guys can check it out.
I ended up mounting them right by my license plate. There was a 12 bolt hole there and I just filled it up!
You can't even tell unless you are really looking for it.
Old 08-15-2009, 04:04 PM
93YotaGuy's Avatar
Well I got my camera back today so here's a vid of my new horn. First in my garage and then on the street.
Enjoy!
Also, make sure the sound isn't too loud!
[YOUTUBE]http://www.youtube.com/watch?v=2dteizgnvHI[/YOUTUBE]
[YOUTUBE]http://www.youtube.com/watch?v=u-df7incssU[/YOUTUBE]
Old 08-15-2009, 08:54 PM
OutlawMike's Avatar
Sooooo much better than the stock horn. I think it is about the same tone as the two that I have, the tone E and tone F. I have mine mounted inside my ARB Bull Bar. It acts like and Echo chamber....
Old 08-16-2009, 06:26 AM
bigt's Avatar
my hilux came with 2 horns under the front bumper... they are LOUD!!!
not air loud but pretty loud!
Old 08-16-2009, 03:44 PM
93YotaGuy's Avatar
Yeah I think mine is a little loud... Definately was expecting it to be a little quieter but I love it!
Old 08-16-2009, 05:43 PM
toyotanick's Avatar
so this is a plug and play type thing?
Old 08-16-2009, 07:09 PM
93YotaGuy's Avatar
Yep plug and play. I jsut bolted it onto my truck and re-routed the horn wire and BAM!
New horn!
Old 08-16-2009, 07:39 PM
toyotanick's Avatar
that is fricken awesome! now i have to actually find one of these cars!
Old 08-16-2009, 07:41 PM
93YotaGuy's Avatar
I'll post some pics tomorrow of the horn and how it is hooked up.
Any electrical horn should work though. Just get one from a big truck or old caddy like I did and you will not be dissapointed.
I payed 4 bucks for mine and it took me about 10 min to put it in
Old 08-16-2009, 07:44 PM
Snow Runner's Avatar
Nice... I swapped my xBs horn for that off of a Saturn SL1 because it didnt sound like a cat being strangled. I might go to the yard later this week and look around
Old 08-16-2009, 07:52 PM
toyotanick's Avatar
would a 68 or 84 horn work?
Quick Reply: Cadillac Horn
