a/c
Old Jun 22, 2008 | 07:42 PM
ben12's Avatar
a/c
It is time to convert my a/c over. I am going to get a friend who dose heating and air on houses to help me so I need to know how much my system holds. 91 YOTA 4 runner, v6
Old Jun 23, 2008 | 01:55 AM
Robrt32's Avatar
if you type ac into the search function, you can read for days
Old Jun 23, 2008 | 11:01 PM
anotherjeff's Avatar
700grams +/- 50grams
Old Jun 24, 2008 | 10:19 AM
dbcx's Avatar
converting to what? 12 to 134
Old Jun 24, 2008 | 10:44 AM
grovedogg's Avatar
I'm in the process of doing the same. I started by replacing the fittings, and made sure there was no refridgerent in the system, began filling, and within about 5 seconds the pressure (low side) flew up to 65 psi... eek, let a little escape, and still will not produce cold air. Does this mean I need to check my compressor?'
Thanks
Old Jun 24, 2008 | 10:46 AM
904_runner's Avatar
Just to make sure!
You were refilling it with the engine running with the ac on max right?
Old Jun 24, 2008 | 12:18 PM
grovedogg's Avatar
yes, after about 3 seconds of filling the compressor came to life, creaking and squeaking, like it was just ressurected from the dark ages!!!
Old Jun 24, 2008 | 06:42 PM
iamsuperbleeder's Avatar
and still no cold air?
clogged up some where it sounds like... I wouldn't run the a/c... in fact you may have already just damaged the compressor if if made all that noise. Probably made the noise because there was no oil in the compressor. My first guess would be the expansion valve; usually the cause of a bad clog. Have you had the system open (ie: lines taken off the comressor) ?
When adding the freon, the pressure should slowly build, it'll start to get a little high, then the compressor should kick on, and it'll drop considerably. There's a fine line between just right and over-full on these truck's I've found. Not sure about the exact pressure or fluid ounce level, but on my 91 22re, if you don't have it filled just right, the compressor kicks on and off. Too much, and it acts like it puts too much of a load on the compressor...
I would suggest having someone try to vaccum out the system...
Old Jun 24, 2008 | 07:29 PM
toyotatom93's Avatar
Hey get your friend who does HVAC to charge you up with the old 12. I used to work for an HVAC company and they stock the old stuff for all the old crap they service.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
BimmerSage
Sep 17, 2015 11:48 PM
Tacoma1313
Sep 8, 2015 01:27 PM
