brake upgrade questions
Old 10-08-2015, 03:07 PM
krisch's Avatar
so i have been looking up but i cannot find the answer,
i have a 1988 4runner 22re.
i upgraded the booster and master from a 95 4runner for the dual diaphram booster and 1" in master.
*** the problem, so driving around normal pedal is fine, about 1-1.5 travel and brakes feel ok, then anything after that the pedal is WAY to hard to push, so i needed to stop quick it wouldnt no matter how hard i pressed.
while upgrading the booster, i seen that with the rodat the pedal the same height for some reason the pedal was off the switch, which caused my brake lights to stay on so i just adjusted the brake switch.
****ANY HELP WOULD BE GREAT******
Old 10-08-2015, 11:20 PM
wyoming9's Avatar
Red face
Sounds like the Rod that engages the Master Cylinder is not adjusted correct.
New Booster has problems This was New Out of the Box ??
Old 10-09-2015, 05:46 AM
krisch's Avatar
it was a new reman, but i think i figured out the issue, im goign to return the booster and get another, it seems and one part of the booster isnt working like since its a dual booster. thats all i can figure out. the rod is measured correctly, i used a rod depth gauge.
4x4-runner
04-18-2017 09:08 PM
rusty904
03-27-2017 05:20 PM
Poppie51
08-15-2015 11:02 AM
smooretahoe
08-14-2015 09:23 AM
4x4-runner
08-03-2015 07:14 PM
Quick Reply: brake upgrade questions
