Brake question! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-27-2007, 07:57 PM   #1 (permalink)
Brake question!
I got my brakes done at Les Schwab a couple of years ago and have had problems with them ever since. I recently redid them myself, and it ends up I'm missing the anti-rattle clips. When driving, I hear a clicking noise that stops when you apply the brakes. It is pretty loud. It also rattles pretty good when I go over bumps. I never had this problem before I had my brakes redone at Les Schwab; I think they disposed of the hardware! I know I'm missing these parts, but the problem is that I can't find a good diagram or information on what I need. CSK auto lists a part that they can't even order. Autozone has a metal contraption that I can't even begin to figure out how it would attach to the brakes, let alone make it stop rattling. The dealer listed something similar to what Autozone sold me. Does anybody have a good diagram or can give me a good description of the anti-rattle clips/springs needed for 4X4 brakes on a '92 4runner? I would greatly appreciate it!
tortex53 is offline
Old 10-27-2007, 07:59 PM   #2 (permalink)
OSU4Runner's Avatar
Send a message via AIM to OSU4Runner
So you need a new set of anti rattle clips? The dealership should have your info for sure
__________________
2006 Tacoma SR5 - Stock for now
2000 4Runner Limited
16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~1st Gen Roll Bar~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap.....
OSU4Runner is offline
Old 10-28-2007, 07:49 AM   #3 (permalink)
GSGALLANT's Avatar
Posting a picture of what you have will make it easier for people to tell you what you're missing.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 10-28-2007, 08:55 AM   #4 (permalink)
Marc's Avatar
Here's a picture of what hardware should be there.
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C, 4.56, 31x10.5x15 Nokian Vatiiva Tires, Taurus fan (removed)
'90 4Runner SR5 V6 4X4 Auto, A/C, 4.56
V6 power with V8 fuel mileage
I've used Fram oil filters and dino oil in all my stuff for 30 years and never had trouble
I bet MOST people who say "swap in a 3.4" have NEVER changed any engine nevermind converting to a different type
Marc is offline
Old 10-28-2007, 09:25 AM   #5 (permalink)
Reldnew's Avatar
I got mine at Autozoned
__________________
Reldnew
91 4Runner-Very Used
but Very Usable!
Reldnew is offline
Old 10-28-2007, 09:41 AM   #6 (permalink)
Luvmeye22re's Avatar
Yup if you're missing that stuff it will cause some small problems. Another thing I firmly believe in as well is if you replace one caliper, you replace the other caliper. What kind of work did they do? Might help nail it down.
__________________
86 Runner with rebuilt 22re and 5 speed swap
Luvmeye22re is offline
Old 10-28-2007, 10:59 AM   #7 (permalink)
Thank you for that picture. That helps. I have the side clip thingies. That spring that goes between the two pads is only on my left brake. When I went to the dealer and asked for that part, they said that it is only on 91 and earlier. 92's have a different part. Autozone sold me the same part that the dealer told me I needed. The only problem is that I can't figure out how it is supposed to be installed! Here is a link to the part that autozone sold me since I can't figure out how to post pictures...
http://www.autozone.com/R,APP1438202...ductDetail.htm
tortex53 is offline
Old 10-28-2007, 11:41 AM   #8 (permalink)
infiltrator's Avatar
Send a message via AIM to infiltrator
you guys will crap your pants when you hear my brakes
i too got mine done and got a "special" deal and that meant i got the crappiest pads that squeak bad..
sucks when you pick up girls...
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled.
infiltrator is offline
Old 10-28-2007, 11:46 AM   #9 (permalink)
toyota_mdt_tech's Avatar
Quote:
From the dealer, there is actually 2 kits you can get. One is the shim kit, this is the shims on the back of the pads and a release spring if equipped. Next kit is the one you are after, called the "fit" of "fitting kit" and its the clips at each end of the pads where they go into the anchor plates. Les Schwab is great with tires, but there brake overhauls consist of all new rebuilt calipers. Problem with their calipers is the plating has been all bead blasted off, so they rust up fast and stick.
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
1998 Chevrolet K1500
1999 Toyota Camry
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Old 10-28-2007, 12:35 PM   #10 (permalink)
You will need to pull the pad retaining pins to put in the anti rattle spring. You'll see what I mean if you take it apart.
__________________
Old 10-28-2007, 12:43 PM   #11 (permalink)
GSGALLANT's Avatar
The new springs that you got should work for you. You hook one end behind one of the brake caliper pins, and snap the other end over the other brake caliper pins. It doesn't really matter which end goes up and which end goes down. And for that kind of spring, you don't need to remove the caliper pins to install them.
__________________
Old 10-28-2007, 04:32 PM   #12 (permalink)
Quote:
The anti ratle spring, we call the "W" clip. Thats what is kinda looks like. Anyway, it does matter which way it goes in. It needs to be on the bottom pin where the caliper is behind the rotor. This not only keeps the pads from rattling left to right, but front to back. And on the bottom, it pushes the pads forward, so when you apply the brakes, the pads are alread forward, this keeps them from doing a "click" each time you step on the brakes. Now it wont work too well backwards, but you are usually moving slow in reverse and only brake a few times that way. After you have this "W" clip in place, kinda pull out on the middle of the "W" to wind it up so to speak, this will keep the clip from rubbing on the rotor and cutting through it as the pads wear down.
__________________
"MDT"
1999 Toyota Camry
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2003 Honda XR50
Old 10-29-2007, 05:27 PM   #13 (permalink)
GSGALLANT's Avatar
Quote:
He doesn't have a W clip. He has a '92, which uses the new style anti-rattle spring. See the pic in post #7.
__________________
Old 10-29-2007, 06:58 PM   #14 (permalink)
Quote:
OK, seen it. That design also has a "backwards", make sure the looped end goes upward. The idea is it also keeps the pads pushed forward.
__________________
"MDT"
1999 Toyota Camry
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2003 Honda XR50
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
brake question metalhed 95.5-2004 Tacomas & 96-2002 4Runners 3 08-28-2006 09:31 AM
Brake question funrunner91 86-95 Trucks & 4Runners 16 02-10-2006 01:38 PM
brake question Glenn 95.5-2004 Tacomas & 96-2002 4Runners 3 03-02-2005 01:11 AM
03 Brake question for all you brake experts The Dutch Man 95.5-2004 Tacomas & 96-2002 4Runners 15 06-26-2004 10:47 AM
2009 InternetBrands, Inc.
