Brake fluid gushing onto my floor - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-12-2008, 08:54 AM   #1 (permalink)
The previous owner said he did not change the brake fluid, so I suctioned some out of the master cylinder to check the color and added some new fluid. I started my truck and pumped the brakes and about every ounce of brake fluid in the master cylinder was pumped onto my garage floor.
The interesting part is that it came out of the truck in front of the passenger side rear tire, not at the master cylinder. I refilled the master cylinder and pumped some more fluid onto my floor out of the same location.
Any idea what is going on here, or did I bust a brake line pumping my brakes?
Any help is much appreciated, I do not want to drive this thing until I figure out what happened.
The truck is a 91 V6 4v4 5spd.
Thanks in advance,
Scott
PCE91V64x4 is offline
Old 01-12-2008, 09:00 AM   #2 (permalink)
85toy's Avatar
did you look to see where its coming from? it sounds like the brake line if it s then just replace it.
__________________
1984 toyota pickup extended cab 4x4
couple of mods
Quote:
Originally Posted by Getsome View Post
Tuesday black tar herion night.
85toy is offline
Old 01-12-2008, 09:07 AM   #3 (permalink)
It is hard to see, since it is behind the body and above the frame., where exactly the fluid is coming from. My idea is to bleed to brakes with my vacuum pump and confirm which wheel it is (probably one of the rear lines....) and replace that line.
Old 01-12-2008, 09:14 AM   #4 (permalink)
leebee's Avatar
check above the gas tank, i had two lines go in that area. cut before and after the tank so you dont have to drop it unless its pretty much empty. just remember to disconnect the lines from the tank and the filler neck assy.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 01-12-2008, 09:17 AM   #5 (permalink)
I think that is the same area. Did yours just spontaneously go? Since you are saying cut before and after the tank, how do you repair the tube with just a section? I was thinking I would have to replace the entire piece of brake tube that is leaking.
Does anyone have a diagram showing the brake tube routing? I am looking through the on-line FSM but not finding one.
Old 01-12-2008, 09:31 AM   #6 (permalink)
Targetnut's Avatar
to properly splice brake lines you should use a double flare fitting. Jus so you'll know getting a double flare on your old lines will be very difficult. It's a real PITA but replacing the whole line that has busted is probably the best way to go. You'll have to drop the fuel tank
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Old 01-12-2008, 09:56 AM   #7 (permalink)
Everyone, thanks for the info, sounds like this will be fun.
Old 01-13-2008, 06:04 PM   #8 (permalink)
leebee's Avatar
mine let go at the mechs shop after i had the oil changed so i left it for them to deal with. i think they cut the old lines, flared them and put new lines in. not sure if they had to drop the tank or not, the bill wasnt too big so im thinking they didnt.
lee
__________________
93 sr5 v6 auto, 4x4
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Brake pedal goes all the way to the floor sdstud212001 95.5-2004 Tacomas & 96-2002 4Runners 44 01-06-2007 10:08 PM
how much brake fluid? celica 86-95 Trucks & 4Runners 8 12-21-2005 10:11 AM
Brake fluid or Diff fluid? Gangus2006 95.5-2004 Tacomas & 96-2002 4Runners 20 09-19-2005 09:14 PM
Brake Pedal To Floor!!!89 Runner 99lspwr 95.5-2004 Tacomas & 96-2002 4Runners 25 04-01-2005 04:32 PM
HELP! Brake peddle sinking to floor... Del 95.5-2004 Tacomas & 96-2002 4Runners 7 10-21-2003 12:04 PM
2009 InternetBrands, Inc.
