bore 60 over
Old 10-14-2008, 09:23 AM
sincal's Avatar
bore 60 over
i just got done talking to the machine shop that has my block and im getting it bored due to the previous owner of the block left water on top of the pistons causing it to rust the cylinder walls. The machine shop says that it has to be bored 60 over. I have been getting my parts through engnbldr and i cant seem to find 60 over pistons. Has anybody bored there block 60 over and where did you get your pistons. Thanks
Old 10-14-2008, 09:28 AM
TOYOTA 1's Avatar
heres some,
http://cgi.ebay.com/ebaymotors/Toyot...mZ170270048129
Old 10-14-2008, 09:29 AM
waskillywabbit's Avatar
It has always been my understanding that you shouldn't go over 40 over on a 22RE, thus probably why Ted at engnbldr doesn't carry 60 over...that speaks volumes.
Old 10-14-2008, 09:32 AM
TOYOTA 1's Avatar
also talk to this guy.. http://stores.ebay.com/My4n_Toyota_W...idZ2QQtZkmthis is where i get my rebuild kits.
good stuff, all oem.
unless your getting theese lol, http://cgi.ebay.com/ebaymotors/Toyot...mZ220262778907
Old 10-14-2008, 09:35 AM
TOYOTA 1's Avatar
Originally Posted by waskillywabbit
I don't think you should/can bore a 22RE over 40.
i have no experience with the .060" over bore. although I'm sure you can bore it out that much! but I'm not saying he should or shouldn't.
i have done about 4 or 5 22re's with .040" over bore,
never had a problem!
Old 10-14-2008, 09:39 AM
sincal's Avatar
I just got off the phone with him and he don't carry them due to he cant get them. He said they are hard to come by unless you get special made. I know this can be done for my brother did it to his 91 yota with a 22re
Old 10-14-2008, 09:59 AM
sincal's Avatar
anybody know a actual shop on the west coast with these parts?
Old 10-14-2008, 10:07 AM
olharleyman's Avatar
Try KEITH BLACK maybe even chevy piston's
Old 10-14-2008, 10:17 AM
sincal's Avatar
I searched keith black but they done make them for the 22re.
Old 10-14-2008, 11:20 AM
sincal's Avatar
anybody have a bored 60 over block they are running now? Any complications?
Old 10-14-2008, 11:49 AM
Ya know after thinking about this you should just get a new/used block .If you go .60 over the walls are going to be so thin and I would bet block heat becomes an issue with such thin walls
Old 10-14-2008, 12:57 PM
sincal's Avatar
the machinest said that he has done about a dozen 22re blocks at 60 over with no problems. I was just curious if anyone else has done this to there own rig.
Old 10-14-2008, 01:02 PM
rdlsz24's Avatar
40 over won't do it?
Rob
Old 10-14-2008, 01:03 PM
camo31_10.50's Avatar
get a new block dude..dont risk the chance of boring it .060 over...thats a lot...like others have said .040 is about the max most people would ever go..infact if i can get my hands on a 22ret im gonna bore it .040 over high performance cam..bigger turbo..alll kinds of little power addies..high horsepower 4 cylinder..lol
Old 10-14-2008, 01:04 PM
blackspyder's Avatar
at .060 over I'd just have it sleeved costs more but will let you get back to the stock piston size and a reputable shop can do it well, a good shop will not advise .060 over on anything less than a BB they would advise sleeving the cylinders or other options.
Silvo-lite, Keith Black, and Eagle all make that size piston but for another application. If you can get the Actual Diameter, Pin Spacing and Pin Diameter. I might can find something (But cheap it aint gonna be)
Old 10-14-2008, 01:16 PM
sincal's Avatar
well my family has been going to this shop for 20 something years and he is very reputable. He advised me sleeving the cylinders but that would cost way to much. And getting a new block is out of the question as to i dont have that much money.
Old 10-14-2008, 01:17 PM
sincal's Avatar
i might just sleeve one of the cylinders due to only one really needs to be bored 60 over and the others would be fine with 40
Old 10-14-2008, 01:24 PM
If your gonna sleeve only one and go 40 with the rest you better 40 over the sleeve job.
uneven piston compression can put you right back where you are now or even worse requiring a new head or block.
Old 10-14-2008, 02:01 PM
sincal's Avatar
Of course i would bore the sleve. Im just saying that if that one cylinder wont clean up after going 40 then i would sleve it and bore the sleve to 40 as well and call it a day. I didnt realize going 60 was that much a pita but i guess it is. I would rather go 40 and not worry about my walls being so thin
Old 10-14-2008, 11:45 PM
khoopes's Avatar
My block is in the machine shop. It has to go 60 over and my machinist said it was OK too. He is the only shop in town that builds racing engines and has been building them for many years, 22R's included.
LEt's get this straight though. It is NOT 60 over. It is 1.5mm and do not bore to 60 because they are not the same thing. We found some 1.5 mm pistons through sealed power I think. If you can't find some send me a PM and I will find out where we are getting them. Toyota carries 1mm but I am not sure about 1.5mm.
Quick Reply: bore 60 over
