Boost problems
Old 11-04-2010, 04:00 PM
GreenFlames's Avatar
Boost problems
howdy, i have a 1987 turbo pickup with the stock turbo and it usually reads 6.5psi which i assume is normal but today it started to sputter alot and it wont spool up past 2psi, and also the check engine light comes on whenever its having a sputtering fit then turns off a couple seconds later. any turbo masters out there???
Old 11-04-2010, 04:06 PM
myyota's Avatar
When was the last time it had a complete tune up including the fuel filter ?.
Old 11-04-2010, 04:11 PM
probably like 30000kms ago. i put some injector cleaner through it but it didnt seem to help. i also just put seafoam through it at my last oils change which was 1500kms ago. this problem just started happening today, it came without any warning so i didnt really suspect the fuel filter.
theking11863
03-19-2016 09:36 PM
RatOmeter
10-22-2015 03:17 PM
Logz808
07-26-2015 07:09 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Boost problems
