Best ring and pinion?
Y'all gave awesome advise on the clutch. The Marlin is terrific. Couldn't be happier.
I need a ring and pinion for the rear. It started shedding teeth.
Richmond Gear still the fav or should I be looking at ....
Best online shop for such a thing too.
Thanks in advance.
Thanks in advance.
Install is more important than brand of gear. IMHO, Richmond Sportsman is middle of the road or worse.
Check out www.gearinstalls.com
Thanks in advance.
Thanks in advance.
Motive is a gear I prefer to set up....also, I like Nitro Gears(in-house from http://justdifferentials.com)
Genuine gear is at the bottom....Richmond is not that good either....Yukon is a case of almost anything can be in the 'Yukon' box so it's good at times and bad at times.
If anybody would know it's this guy!!! X2 on the importance of a proper set up.
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
