Bad Bad Gas Mileage
Old Nov 20, 2007 | 05:47 PM
BrunswickYota's Avatar
Bad Bad Gas Mileage
Ok
I have changed the sparks plugs
The wires
New Air filter
New tires, and full to spec
Injector cleaner
Idle and timing checked and adjusted
And i am still getting bad gas mileage, i dont know what it is and need some help, i know it is a suv and wont get the best but i do know i should be getting better, plus i checked all my vacum lines, got them all hooked up and no leaks but i am riding rough around 30 to 50 mph, like a lag and kinda catch up feel..
any hints? i am spent thinking about it, i cant figure this thing out
1992 v6 3.0L
Old Nov 20, 2007 | 06:48 PM
90inworks's Avatar
Replace your fuel filter that should help alot it sounds like when your on the gas its trying to push alot of fuel and its cloging the filter and causing it to spit and sputter? if that makes scense it sounded good to me? lol
Old Nov 21, 2007 | 05:46 AM
dcg9381's Avatar
You can't look for vacuum leaks - you've got to use propane or start spraying things down to catch them.
The other big influence on mileage is the 02 sensor... .
Old Nov 21, 2007 | 06:50 AM
SEAIRESCUE's Avatar
-check for codes the computer may be logging...search this site on how to jumper the diag port under the hood to extract codes and determine what they imply.
-Got oversize tires?
-Fuel filter sounds like a good idea
-Timing?
-Low compression?
-Check vacuum at hot idle...18-20, steady, is good
-Clogged Cat Converter?
-Old Oxygen Sensor...when they start to go, so does your mileage
Report to us your findings....
Old Nov 21, 2007 | 02:41 PM
tarpon40's Avatar
similar problems
I had similar problems after having the distributor go out, and had it replaced by a Toyota dealership. Seemed like I got less power and mileage after thay did it. After trouble shooting we discovered the timeing was way off. As a result of the timeing being way off, now I have two bent and burned exhaust valves. Of course the dealership won't stand behind their work.
After my experience, I would check the timeing, and the compression. Rule out the big stuff, and the stuff that can cause more damage.
Old Nov 23, 2007 | 12:34 PM
FredTJ's Avatar
Originally Posted by BrunswickYota
Ok
The wires
New Air filter
Injector cleaner
And i am still getting bad gas mileage, i dont know what it is and need some help, i know it is a suv and wont get the best but i do know i should be getting better, plus i checked all my vacum lines, got them all hooked up and no leaks but i am riding rough around 30 to 50 miles per hour, like a lag and kinda catch up feel..
1992 v6 3.0L
What mileage are you getting ?
What you consider "bad" and what is "normal" may be the same thing
Fred
Old Nov 23, 2007 | 01:55 PM
TC4RNR's Avatar
don't know about if the fuel filter would really help. i had mine replaced with last month along with the clutch. i couldn't see any differences on the MPG. by the way, the new FF is OEM straight out of the sdealership. see my sig for my rig. still runs about 15.5mpg half hwy half local.
Old Nov 24, 2007 | 10:47 PM
notanymore's Avatar
you should try replacing your o2 sensor
Old Nov 25, 2007 | 01:56 AM
ozziesironmanoffroad's Avatar
check your cold start injector, it might be bad and flooding the engine. also mess with your air to fuel ratio. get in there with propane and check vacuum leaks, all that.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
shisha1999
Sep 21, 2015 08:22 PM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
